Peter Mugridge
The combined volume quotes 39 tons though.
39 tonnes per car
3 Bogies weighing 12 ton each (3 x 12 = 36) plus bodwork 3 ton approx
Regards
Also just realised the Metro I was on to St James on Thursday went into platform 2 instead of one. Makes a change.
Doesn't sound like the plans to go any further west than St James will ever come to fruition, all we hear now is that it will be too expensive to bore through the rock. Easier to put trams into the west end, until Project Orpheus vanished.
Aye it seemed to quietly disappear a while back, hard to find any mention of it now. Also had some bad news last week, seems as if there is going to be jobs cuts soon (according to the papers). Hopefully they will have some in two years' time.
What is the situation with DB advertising for jobs? I have only seen a few around on job sites but Nexus put theirs on the website, but are DB able to use Nexus to advertise vacancies?
I had noticed that, was tryimg to work it out but I can't see any possible way to do it.Going back to level crossings, was on a train from Sunderland to Airport today, got to East Boldon and the signal just before the crossing was red, although I could see the ones in the distance were green. Barriers went down and signal changed to green, train moved off. However in the distance I could still see traffic crossing the line at the two crossings at Tile Sheds, even after we had went past the last signal protecting those two crossings. Made me think, what would happen if there was a problem with the barriers there, how could a train be stopped in time to prevent an accident?
Not sure what you mean by that, as once past the last signal (will have to get its number one day), the next signal is after the two level crossings.
That's true for the ones on the 'main' network such as Fawdon, Callerton, Kingston Park, Bank Foot and Howdon, as they are all either just before or after stations. However on the Sunderland extension the half barrier crossings are where the Metro is going full pelt (and normal trains as well), so if for some reason there was a problem with the barrier, the train may not be able to stop in time.
This is what is surprising me about this threaad. The situation described here is no different to AHBs elsewhere on Network Rail's system. Train speeds are limited to 100 mph at an AHB (unless normal line speed is lower of course), and there is NO interlocking with the signals. Train drivers do not slow down for AHBs...
While at the open day I was told (when sitting in the driver's seat - highlight of the week) that the Metros will be in a semi-permanent coupling when they return from Doncaster, so this means only one cab will be refurbished. Guess this means that Nexus have abandonded the single carriage working plan that they had a few years ago?
Whereabouts was the drivers room? There was a small room next to the canteen but was being used by staff. Quite surpirsed about the hot drinks machines, 10p for a coffee or tea! Cheapest cup of tea I've had in years!
Got a new cup as well, looked like they had some leftovers from ones given to staff. Also a pen about reducing SPADs. All in all a very interesting day.
