Underground track swap
Discussion in 'London Underground' started by TRAX, 13 Jun 2019.
  1. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    Hello all
    Just a little curious question, in several places on the LUL network the tracks swap from left to right and vice-versa. For example between Oxford Circus and Highbury & Islington on the Victoria Line, or between Elephant & Castle and Moorgate on the Northern Line. Why is that ?
    Thanks !
    Rail Forums
  3. transmanche
    transmanche Established Member
    5,470
    27 Feb 2011
    If you look at Euston on that map, it becomes clearer. In order for the Victoria line and Northern line City branch to have a northbound-northbound and southbound-southbound cross-platform interchange at Euston, one direction of the Victoria line needed to 'roll over' the other. There just isn't room between Kings Cross St Pancras and Euston to do this, so it happens between Highbury & Islington and Kings Cross St Pancras. They 'roll back' between Warren Street and Oxford Circus.
  4. si404
    si404 Member
    506
    28 Dec 2012
    It's so the level interchange at Euston can be paired northbound to northbound and southbound to southbound.
  5. AM9
    AM9 Established Member
    6,597
    13 May 2014
    St Albans
    In some cases, it is a historic consequence of lines being extended, e.g. White Cit Central line where the previous formation of an anti-clockwise loop is now used as part of the main running lines. More recent layouts are designed to optimise interchange flows, reducing the amount of interconnecting pedestrian traffic through tunnels. In reality, whether left or right-hand running is practiced, in separate deep tube tunnels, that is irrelevant to ordinary passengers.
  6. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    Ah I see that makes sense ! I can’t see a similar situation for the Northern Line example, why is it also the case here ?
  7. Bletchleyite
    Bletchleyite Veteran Member
    39,940
    Up and down the south WCML (mostly)
    Because the lines run roughly east to west, so north-south is in opposite directions when they meet, if you see what I mean.
  8. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    No I don’t get it, sorry. :'(
  9. transmanche
    5,470
    27 Feb 2011
    That's probably a bit more complicated. The station at Borough was constructed by the C&SLR so that the northbound tracks/platform are above the southbound tracks/platform (this often occurred to keep a railway underneath a road and avoid having to pay for expensive wayleaves for tunnelling under a property). The arrangement of tracks towards the King William St was 'somewhat complicated' and further complicated by the diversion of the route to London Bridge and beyond.
    If you look at the Wikipedia article for the C&SLR there's an excellent engineering diagram of the original route, which is probably the best explanation.
  10. PeterC
    PeterC Established Member
    1,906
    29 Sep 2014
    So by changing at Euston and Kings Cross in turn you can spend the whole day going "north" and end up where you started.
  11. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    I see but couldn’t this have been done nonetheless while keeping the classic track position ?
  12. transmanche
    5,470
    27 Feb 2011
    At Euston? No. Look at the map. Look at platforms 3 & 4, the northbound platforms. If you moved them to be north of platforms 5 & 6 (the southbound platforms) how are you going to 'thread' the tunnels through? And do it without closing the Northern line for a few years. All for the sake of looking 'neat'?
  13. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    No I’m talking about the Northern situation between Elephant & Castle and Moorgate.
  14. bramling
    bramling Established Member
    6,238
    South-east / Barnard Castle
    I think the generally accepted explanation is that the *original* line to King William Street was built this way, primarily because it was decided to built the most difficult tunnel first, which was that closest to London Bridge (as in the bridge) and closest to the bed of the river - which meant the easternmost tunnel was the higher of the two. With the need for the tunnels to converge for passing beneath a narrow street north of the river, and with King William Street station being somewhat higher, it was therefore natural that the easternmost / higher tunnel became the northbound in order to give it the easier gradient up to the terminus. When the line was extended to Moorgate, this had to be continued as there was insufficient space to roll the tunnels over until north of Bank.
    Possibly the more interesting question is why the C&SLR chose to revert to left-hand running south of Borough, when they could have just built the whole railway with right-hand running. I've never really seen an answer to that.
  15. transmanche
    5,470
    27 Feb 2011
    I posted a response to that in post #8.
  16. TRAX
    TRAX Member
    752
    2 Dec 2015
    Paris
    I get it. Thanks everyone for the answers !
Share This Page
