The Kinchbus 9 is bright yellow an blue and a solo and says 'Loughborough' on the front and even says the route map on the side. It runs from Broadmarsh to Trent Bridge to lots of other places to Loughborough.
The Nottingham city transport 9 goes from Victoria Centre to train station to trent bridge to Compton acres and Rushcliffe. This bus is green and says 9, Compton Acres on it..
There not cross city routes.
The 2 services don't even start at the same place in the city and its only the small section between the train station and Trent Bridge that is being mimicked. As Trent Bridge to City sees services: 1, 2, 3, 4, 5, 6, 7, 8, 10 , 11, RC , CC, KC, BXP, Kinchbus 9 and numerous local ones, the chanches are sim of you getting on board the wrong bus.
The station is exactly the place where there are likely to be visitors to the city - I've had to explain it to people there myself. If you have been told to get the 5/6/7/8/9 and get off at say Central Avenue, you may not know where the bus is heading for but you might know that both Loughborough and Central Avenue are vaguely in the same direction so it would be quite easy to board the wrong bus. If you have also been told the fare to pay you might be none the wiser, as IIRC one of the stages of Kinchbus is £1.70 too. By the time you wonder where Central Avenue has got to, the Kinchbus is probably somewhere out in the wilds beyond Ruddington. It was even more confusing when there was an X9 on a similar route as well.
As far as I'm concerned there is no need to have bus route numbers unique across the country but operator and local council heads should be knocked together to ensure that all bus routes passing through a particular community have their own numbers. If that isn't the case then I see little point in buses carrying numbers at all.
Hmm, should we also introduce different numbers in each direction, so that someone doesn't board a cross city route in the wrong direction?
Where does it end?
Routes that make circuits in opposite directions usually have different numbers, including the NCT 8 and 9. The difference between this and a cross city route is that the direction of travel should be made clear on the stops and it's unlikely that the same route will use the same stop (on the same side of the road) in both directions.
