Upcoming Activity for LSE
RJ
25 Jun 2005
Rail replacement bus cab
This one will be the 10:00 Selhurst - Hither Green via London Bridge, Tonbridge, Redhill, South Croydon, Eridge, Spa Valley and Sevenoaks. FM 47s are back on it, although its the Blue Pullman pair, 47709 and 47712. Along the way, you will encounter other interesting movements such as 47816 dragging a 456, EPS 37s dragging a Eurostar and a 20 + 37 utilising the spare daytime path on Dungy - Willesden.
Required items needed are;
MSTS Bin + eng file utility recommended but not essential
LSE
London Brighton Express and Addpack (For 319, 455, 456, MPV and freight wagons)
Great Electric Locos (For the 92)
37029 from UKTS
47709/12 pack from UKTS
20307/2 pack from UKTS
56301-3 pack from UKTS
47816/29/43 pack from UKTS
Eurostar from UKTS
Class 171 from UKTS (By Rich P)
MT Class 313 + 508 from UKTS
BR FNA wagons from UKTS
EWS FKAs from UKTS
Porterbrook Barrier coach from UKTS
E-Rail Mk2s from E-Rail Site (May be available from UKTS)
I aim to upload this in the week.
^47712 moves away from the signal check at Selhurst on 10:00 Selhurst - Hither Green. 47816 is in the background on the 5Z19 Selhurst - Wolverton 456^
^47712 passes Forest Hill among the regular units^
^47709 leads the SERCO out of London Bridge with familiar units in the background^
^47709 meets 92016 + 37604 on a very long freight train from Dollands Moor^
^A diverted 4E90 Grain - Doncaster observed from the cab of 47709 at Sevenoaks^
^47709 meets 37603 and 37601 on 5X11 Dollands Moor - North Pole^
^20307 and 37029 growl through Tonbridge on 6M93 to Willesden^
^http://rjhamilton.fotopic.net/p36285859.html^
Coxster
9 Jun 2005
Wicked! I think this will be such a great activity as a Serco train covering virtually the whole route with prototypical real-life AI trains with the previously mentioned 'bonus' 456 drag, Eurostar drag, Fastline 56s and Nuclear Flasks etc! Shame about the need for the Great Electric Locos pack as very few people in the community have that as the locos are not really as good as the freeware stuff. For example there are only a couple of UK locos in it and those appear not to be as good as the freeware stuff.
As stated you require LSE, LBE and Great Electric Locos to be installed however here are the UKTS URLs:
EPS Class 37 37603 - http://www.uktrainsim.com/filelib-info.php?form_fileid=8404
DRS Class 37 37029 - http://www.uktrainsim.com/filelib-info.php?form_fileid=8364
Blue Pullman Class 47s - http://www.uktrainsim.com/filelib-info.php?form_fileid=13885
DRS Class 20 Pack - http://www.uktrainsim.com/filelib-info.php?form_fileid=4803
Fastline Class 56s - http://www.uktrainsim.com/filelib-info.php?form_fileid=14257
47816/29/43 pack - http://www.uktrainsim.com/filelib-info.php?form_fileid=14879
Class 373 Eurostar - http://www.uktrainsim.com/filelib-info.php?form_fileid=9591
Southern Class 171 - http://www.uktrainsim.com/filelib-info.php?form_fileid=9370
Making Tracks 313 - http://www.uktrainsim.com/filelib-info.php?form_fileid=12415
Making Tracks 508 - http://www.uktrainsim.com/filelib-info.php?form_fileid=12374
FNA Nuclear Flasks - http://www.uktrainsim.com/filelib-info.php?form_fileid=208
EWS FKAs wagons - http://www.uktrainsim.com/filelib-info.php?form_fileid=13852
Porterbrook Barrier - http://www.uktrainsim.com/filelib-info.php?form_fileid=11238
Railtrack/Serco Mk2s - http://www.uktrainsim.com/filelib-info.php?form_fileid=14895
RJ
25 Jun 2005
If you need some of these files copy and paste this list of numbers into http://www.uktrainsim.com/filelib-fileid.php and choose what you need.
8364
13885
4803
14257
14879
9591
9370
12415
12374
208
13852
11238
14895
12694
8404
37029
47709/12 pack
20307/2 pack
56301-3 pack
47816/29/43 pack
Eurostar
Class 171
MT Class 313
MT Class 508
BR FNA wagons
EWS FKAs
E-Rail Mk2s
EPS 37603
Additional note;
File 12634 (92007) isn't in the activity but I don't think a lot of people will have the 92 included so its a good alternative. http://www.uktrainsim.com/filelib-info.php?form_fileid=12634
Coxster
9 Jun 2005
Where are the EPS 37s from? They don't appear to be in the list, nor does the wagon between them and the Eurostar.
RJ
25 Jun 2005
My bad - you'll only need 37603 ;) and thats File ID 8404 The wagon between the Eurostar and the 37 is one from LBE Addpack :)
Final draft - activity sent to UKTS now :)
You will be driving both 47712 and 47709 in top and tailed mode on this SERCO trip around the South of England. Firstly, you must wait for the 10:01 Norwood Jn - London slow service to clear the road. You will be given priority out of Selhurst over 47816 on the 10:30 456 move. After Norwood Junction, you will be riding yellows up to Bermondsey as there is a fast Thameslink/FCC train in front of you. Upon arrival at London Bridge, either reverse when you stop or if you are on MSTSBin, hit F5, chose the rear loco and press 1 twice to switch locos. You must perform this before 10:15 otherwise you will lose your path and the 10:16 and 10:18 services will leave London Bridge before you, then you'll have to wait for various South Eastern units to clear the lines. If you leave on time, you will be given greens and the fast line again. You must stop at Orpington for a refreshment and to await the unit from Sevenoaks to cross over onto the slow lines. The road will clear at 10:30. After this, you will have a clear run to Tonbridge, where you will reverse again and take the line to Redhill. Then, up to South Croydon to pick up a member of crew, reverse there and take the Weald line to Eridge. Here, you will reverse in the bay platform, and you will have to gain permission to the Spa Valley by performing a signal check. Then, you should have a fairly clear run up to Grove Park, where you will drop off a crew member then proceed into Hither Green Loco Holding Sidings. Stop when all of your train is in the siding. Enjoy!
Times are;
Selhurst RMSD 10:00
Norwood Jn 10:03 (Fast Line)
Forest Hill 10:07
London Bridge 10:14 - 10:16
New Cross 10:20 (Fast Line)
Hither Green 10:23
Chislehurst Jn 10:26
Orpington 10:29 - 10:31
Sevenoaks 10:37
Hildenborough 10:39
Tonbridge 10:42 - 10:45
Penhurst 10:51
Redhill 11:04 - 11:05
South Croydon 11:14 - 11:15 (Wealden Line)
Eridge 11:30 - 11:30
Tunbridge Wells 11:45
Tonbridge fast line 11:51
Orpington 12:05 (Slow Line)
Grove Park 12:24 - 12:25
Hither Green LHS 12:30
Coxster
9 Jun 2005
Nice - seems like it will be a great 2.5 hours :p Thank goodness you can now make MSTS 'Bin' rear cabs easily with the utility as it means we won't have to use reverse therefore being able to change locos.
Coxster
9 Jun 2005
I've changed the consist to use this as I don't own the other pack and will give it a go later.
