Updated Easement List? + 030098
Starmill
18 May 2012
Bolton
There is a new List of Easements here, (linked to from here and scroll down to Section E). The date is 29/04/2015. The text at the top has changed to now include: "An easement which narrows permission is a negative easement.". What's that old quote about the more times you repeat something that isn't true, you make people believe it is?
Anyway moving on from their latest attempt to 'get one over' on people, by using the most convoluted and nonsensical wording imaginable (either that or simply major levels of incompetence I guess!), may I draw attention to 030098 a 'Routeing Point' easement (no definition of that appears to be given?) which states:
"Journeys from Chandlers Ford via Eastleigh and Basingstoke are permitted regardless of fares. This easement applies in both directions."
Which journeys are not permitted regardless of fares? They are permitted according to... well, weather they are permitted or not, as per the Routeing Guide, as set out in the National Rail Conditions of Carriage. Why would fares influence that? Therefore the only remaining logical interpretation is that all journeys from Chandlers ford are permitted via Eastleigh and Basingstoke.
So Chandlers Ford to Romsey via Eastleigh, Basingstoke and Salisbury is fine, right?
cool110
12 Dec 2014
Preston
...may I draw attention to 030098 a 'Routeing Point' easement (no definition of that appears to be given?) which states:
That easement is removing the requirement to apply the fare-check rule when finding an appropriate pair of routeing points.
As for your example. Chandlers Ford and Romsey share one or more routeing points so only the shortest route +3 miles is permitted and direct trains to and from one of the common points, therefore the fare-check rule and the easement don't come into play at all.
greatkingrat
20 Jan 2011
If they mean that Eastleigh is always an appropriate routeing point for Chandlers Ford then fine, but I don't see what Basingstoke has to do with it?
Starmill
18 May 2012
Bolton
I see. But it says 'regardless of fares'. Surely if thy mean what you say it would say 'without the need to apply a fares check' or similar.
Then again there are so many hilarious mistakes in these new 'negative easements', such as:
"030156 For journeys to Pokesdown and Christchurch via Southampton Central may doubleback from Bournmouth. This easement applies in both directions."
I don't suppose they can be trusted to proof-read even once!
I completely agree yes. But then why not simply say that?
TUC
11 Nov 2010
Cannanyone explain the purpose of 030236 'customers traveling from Durham and Chester-le-Srreet to Northallerton and beyond may travel via DarlIngton'? That would presumably be valid on a shortest route basis anyway (and is the logical route that almost all passengers would take so I'm not sure what it's seeking to address).
Merseysider
Fares Advisor
22 Jan 2014
Perhaps it's patchwork to resolve a bug eg some tickets only being offered via Sunderland and Thornaby? Your guess is as good as mine
kieron
22 Mar 2012
Connah's Quay
It could be meant as something like "If there is a permitted route from Eastleigh to (say) Trowbridge via Basingstoke, you are allowed to travel from Chandler's Ford to Trowbridge using that route between Eastleigh and Trowbridge."
There isn't a permitted route from Eastleigh to Trowbridge via Basingstoke, and Eastleigh-Trowbridge single tickets cost the same as Chandler's Ford-Trowbridge ones anyway, so it doesn't affect this route.
I don't know what tickets it would affect now. As this is an old easement, it may well be obsolete now.
It is if you're going to Northallerton, but may not be if you're going beyond there. For instance, take Durham to Barrow-in-Furness.
The shortest route is via Carlisle.
Barrow is associated with Carlisle and Lancaster Group (Bare Lane, Lancaster and Carnforth).
Durham is associated with Newcastle and Darlington.
A Durham-Barrow anytime day single costs £50.50.
Lancaster, Carlisle and Newcastle pass the fare check, but Darlington does not.
Routes from Newcastle to Carlisle and Lancaster all go via Hexham.
So no routes via Darlington are offered before I reach the easements.
NRE offers itineraries via Darlington, although sadly only via Manchester rather than Skipton.
Starmill
18 May 2012
Bolton
Some easements there at first appear 100% redundant.
For example 030018:
Journeys from Ludlow via Shrewsbury and beyond may travel via Craven Arms. This easement applies in both directions.
Gosh, how generous of them. I would never have imagined you're allowed to go from Ludlow to Shrewsbury ('or beyond') via Craven Arms...
Ditto 030031:
Journeys from Wellingborough to Luton and beyond may travel via Bedford (Midland). This easement applies in both directions
Really? Would never have guessed!
But of course there may be journeys which would not otherwise be valid without these. I'll be very impressed if anyone can come up with some, but take care with your interpretation of 'and beyond'! :p
PS Another prize if anyone can tell me what the difference is between 'Via X and beyond' and 'To X and beyond' :lol:
pennine
8 Aug 2010
Customers holding tickets routed NOT DARLINGTON may travel via Darlington using
specific train UIDs (Y23904, Y32903, Y32002, Y32924 and Y32657) only. This easement
Could someone please dumb this down for me? :D
