theblackwatch
- Joined
- 15 Feb 2006
- Messages
- 10,713
I suspect that you wouldn't just get a "reason 23" type response; you would likely be given an actual reason for it along the lines of "…duplicate post" or “…that used to be the case but the rules were changed"
I don't know myself as I don't think I have had any posts deleted, but knowing some of the staff on here, they would give you an explanation.
Personally I can't see any reason why the information couldn't be made public, but obviously there may be reasons I have not thought of.
Reason 23 is 'Bad Language'.
If a post is deleted, you get an actual reason given, not just a number. The numbers are just there for us so we have them in an order grouped together in our pull down list. The reason's aren't 100% fixed either, if we find we are deleting a post and there isn't really an appropriate reason code, we will simply add it if we think we need to and it will probably come up again. As someone suspected, some codes get used a lot more than others! Hope this clarifies things a bit.
