Upgrade two Advances to Return?
erk
21 Nov 2012
If I have two Advance tickets, London to Manchester and Manchester to London, can I convert them to an Off Peak Return? Presumably two admin fees at £10 each would apply as well as the difference in price.
Can I do this at a station, for tickets that were bought on-line (on the VTWC site)?
Ross
erk
21 Nov 2012
Thanks Yorkie, but I'm not sure my specific question is covered. I think the nearest is where the FAQs refer to "Changing both legs where a walk-up return becomes cheaper." In my case I want to buy flexibilty. With no particular trains in mind, it's not possible to specify Advance fares so not possible to decide if a walk-up is cheaper.
On reflection, there's a further complication. What I want to do is to convert London to Manchester plus Manchester to London to a return starting at Manchester (i.e. in the opposite direction).
Ross
I don't see how this is a complication. You are allowed to change the date and/or time of Advance tickets so it doesn't matter that the London to Manchester ticket is currently earlier than the Manchester to London one.
Paul Duck
17 Jan 2014
Eaglescliffe
Ross
You certainly can. We do a quite a few at Eaglescliffe.
erk
21 Nov 2012
Thanks for all the info. In the event I changed the tickets on-line (VTWC site). It was a bit convoluted, to ensure I got a return and not two saver halves. I could only get a return in the original direction.
Haywain
3 Feb 2013
Because what you wanted to do was slightly unusual and completely within the rules but more difficult to interpret electronically, I believe.
I suspect that's due to the way the website has been coded.
If you went to a competent ticket office, they could have done it.
Was there a particular reason you wanted a return rather that two saver halves, assuming you were going to make both legs of the journey?
erk
21 Nov 2012
Yes, a saver half is valid on one day only (break of journey excepted); the return half of a return is valid for a month. I wanted the flexibility.
In the end, juggling with another return half I already had I was able to get the tickets I wanted. Comments above about the limitations of the web system are probably right. If I'd really needed the "reverse" ticket, I'd have gone to a station.
Ross
