It’s at Ipswich at minute so likely to work a northbound freightliner at some pointDoes anyone know is 66509 is scheduled on anything today? Thanks in advance
700144Please can anyone post what’s on today’s:
9J22 0855 Horsham to Peterborough
Many thanks.
Many thanksIt’s at Ipswich at minute so likely to work a northbound freightliner at some point
Will keep eye out for it, likely to go back on Trafford Park or Ditton morning servicesMany thanks
Hello,
Does anyone know what's on this: Realtime Trains - 134D 0950 Derby R.T.C.(Network Rail) to Exeter Riverside N.Y.
Thanks,
Thank you!!37099 and 37254 on 1Q59, with coaches 975091, 72631, 6262 and 9523.
Hello,
Does anyone know what's on this: Realtime Trains - 692O 1159 Westbury Down T.C. to St Erth
Thanks,
Note: Sorry, forgot to merge with the last message.
700144
Thank you.66167 and 66020.
Hi can anyone tell me what is operating the following services today:
1. 1V50 06:06 Edinburgh to Plymouth
2. 1E63 15:27 Plymouth to Leeds
3. 2B86 21:15 St James' Park to Barnstaple
Thanks
Thanks, I did have a look on there first but it looked as if 43304 and 301 were heading into Laira which indicates a swap occuring as that happens every now and then in the afternoon.43304 and 43301 on both.
I found them both on RTT so perhaps you didn't know that XC, Northern, GBRF, Caledonian Sleeper, Scotrail show them on RTT at the top of the schedule. I may have miissed one but there is a move for all TOCs to show them but whether they will all show them in time is debatable. It has been well documented on the Forum.
Yeah does look like 1V50 went empty to Laira and new set comes to form 1E63Thanks, I did have a look on there first but it looked as if 43304 and 301 were heading into Laira which indicates a swap occuring as that happens every now and then in the afternoon.
Yes. That did happen and 1E63 was 43357 and 43285 and which are now in the system.Yeah does look like 1V50 went empty to Laira and new set comes to form 1E63
Yes, just seen myself as well, thanks for the information.Yes. That did happen and 1E63 was 43357 and 43285 and which are now in the system.
It worked the 09:32 Felixstowe to DittonWill keep eye out for it, likely to go back on Trafford Park or Ditton morning services
Many thanks hopefully works back tomorrowIt worked the 09:32 Felixstowe to Ditton
think it does 0118 Ditton to Basford Hall. After that anyone’s guess, maybe back to Felixstowe on 4L41 0600.. who knows, will look on morningMany thanks hopefully works back tomorrow
Thank you very much for your help 55002think it does 0118 Ditton to Basford Hall. After that anyone’s guess, maybe back to Felixstowe on 4L41 0600.. who knows, will look on morning
It did work to Basford Hall on 0118 from Ditton but not on 0600 from thereThank you very much for your help 55002
Many thanks. Much appreciatedIt did work to Basford Hall on 0118 from Ditton but not on 0600 from there
What loco are you enquiring about ? I’ve got access to TOPSMany thanks. Much appreciated
66509 at BasFord Hall, cheers DaveWhat loco are you enquiring about ? I’ve got access to TOPS
