• Dear Guest, and welcome to RailUK Forums. Our non-railway discussion forums are currently restricted until members have five or more posts, and you will not be able to make a new thread or reply to an existing one in this section until you have made five or more posts elsewhere on the forum.
URL shorteners ....
David
9 Jul 2005
Scunthorpe
I've just made a post that included a link to streetmap.co.uk. Instead of posting the huge URL I used an URL shortening service. However ....
Tiny URL, Bit ly, is gd and a couple of others are all censored, with the links showing as http://*******.com. Any particular reason?
ert47
28 Feb 2010
Its probably to avoid spam, when posting a link, its probably best to use the Hyperlink tag.
David
9 Jul 2005
Scunthorpe
True, but when you have an URL that contains square brackets, such as Streetmap, then the URL link won't work, hence the URL shortening service.
ert47
28 Feb 2010
Ah ok, but you can use the shortened links in the hyperlink tag?
David
9 Jul 2005
Scunthorpe
Not is the links areblocked for whatever reason. Examples of what I mean ....
http://www.streetmap.co.uk/map.srf?...ap+of+Scunthorpe+Station,+North+Lincolnshire+[Station]&searchp=ids.srf&mapp=map.srf - Normal URL. The square brackets stop the link from highlighting fully, and may not work.
&searchp=ids.srf&mapp=map.srf]Using the URL tags. As you can see, because of the square brackets, it looks a mess, and the link isn't guaranteed to work. Now for the 3 most commonly used URL shortening service ....
http://*******.com/7yrxae7 - Tiny URL
http://*******/yTsZLx - Bit ly
http://******/K6clru - Is gd
ert47
28 Feb 2010
I mean't couldnt you just use the ******* (or whatever shortener you used), put it in the hyperlink tag and then name the link something relevant? Eg. "map", "source" etc.
I'd show an example of it, but im currently on my phone on the way to work.
EDIT: lol, looks like naming the specific url provider is blocked
Badger
17 Oct 2011
Wolverhampton
They pose a security risk as malicious urls could be linked to without anybody knowing what they actually link to. Not just Nimp and things like that but also sites which might exploit cross site scripting etc.
michael769
9 Oct 2005
This - one should only click on a shortened URL if it comes from someone they know well and trust. And even then only if you can be sure that they got it from a reliable source.
There is no need to use a URL shorter on a forum, as most forum software will automatically shorten how it is displayed, or the poster can supply their own shortened text for the link.
Lrd
26 Jul 2010
If you tick the "short URL" box when you're making the link it'll make an even shorter g.co address (which isn't blocked by the forum, as it's not a public URL shortener).
http://g.co/maps/452xw
I tried doing that, but it never shortened for me, shame as that is what I was trying to do anyway.
