Use of 7xx and 8xx numbers
61653 HTAFC
18 Dec 2012
Another planet...
I personally think we could have alpha-numeric (numero-alphabetic? is that a word?) classes so the range would be 57, 58, 59, 5A, 5B, 5C, etc. It probably won't happen, but it would create new 'numbers' within the correct range.
I was worried the suggestion of 3-digit loco classes would cause widespread meltdowns among forum members... yet you've doubled down on that! Letters? Madness! <D
trash80
18 Aug 2015
Birches Green
One thing the new ranges don't allow for is future new classes of locomotives. The 70s already broke the system (69 would've been more logical, but would've prompted lots of unfunny jokes) but we're running out of unused 2-digit numbers (though they can be re-used like 43 and 70) so it wouldn't surprise me to see a new loco class be given a 3-digit class number in the 6xx range.
When they added the 600-899 number blocks they extended diesel locos to 79. With unused numbers there should be enough for a while.
D365
29 Jun 2012
Hexadecimal?
As above, the DC loco classes (other than 73 - of which the /9s are essentially diesels anyway) can easily be reused.
southern442
20 May 2013
Hexadecimal?
Especially considering plenty of numbers were allocated to single (or a very small fleet of) prototype units.
Joe Paxton
12 Jan 2017
Well I mean the 3xx numberings were going ok:
37x for electrostars (375-9)
38x for Scottish electrics (380, 385)
39x for high speed electrics (390, 393, 394, 395, 397 (ish))
3x0 for Desiros (350, 360, 380)
And then the 387 and 399 had to ruin it all...
Numbering really is a mess...
Does it actually matter?
AM9
13 May 2014
St Albans
The next wacky discussion for naming/numbering might be to rename stations such that each line has a same suffix or prefix, e.g. Liverpool St Elizabeth, Farringdon Elizabeth etc., or Virgin Crewe, Virgin Stoke On Trent. Anything to start a discussion.
BlythPower
15 Jan 2009
Kenilworth
There are plenty of spare double numbers for a little while yet. 61-65, 32, 34, 36, 38, 39, 48, 49, although some have been allocated in the past and not subsequently used. 43 is already on it's 2nd use with HST power cars.
38xxx would clash with cl. 378 and 380 vehicles and 61-65xxx would clash with loads of EMUs.
mallard
12 Apr 2009
Considering that the first digit of a loco's number is supposed to be its power class, those 3x and 4x numbers are quite unlikely to find a use; I doubt anyone plans to build any new locos with less than 2500hp. That means we've only got 4 (5 if someone decides to use 69) available numbers for new diesel locos!
I expect the 7x range will end up being used by diesels before a new solution is found.
Domh245
6 Apr 2013
nowhere
That may be the case historically, but as I understand it, the power class rule is no longer applicable so not an issue.
AC47461
13 Feb 2017
RAYLEIGH, ESSEX
I should have clarified in my original post that given the blurring of use of class numbers for multiple units, it wouldn't be surprised if the same happened for loco class numbers too. I think the allocation of unit numbers has got out of hand (in my opinion). There is only so far the TOPS based numbering will go, especially now that some coach numbers in units are 6 character. Perhaps it's time for a complete rethink?
xotGD
4 Feb 2017
Here's a radical idea - you could prefix the numbers of diesel locomotives with a D and electric locomotives with an E. I can't understand why no-one has thought of this before...
D365
29 Jun 2012
Very helpful for computer systems ;)
jopsuk
13 May 2008
as I've posted before, my solution would be quite simple:
8 digit vehicle numbers. Scrap all the current vehicle numbers and start again.
For an MU, each carriage would be:
WWW X YY ZZ
where
WWW: class number
X: Sub class number
YY: Unit number
ZZ: vehicle number (including a leading zero for coach 01-09)
For a loco, each would be
0WW X YY 00
where
WW: Class number
X: Sub Class number
YY: Loco number
For coaches and wagons:
WWW XX YYY
where
WWW: Coach type class
XX: Sub type
YYY: Serial number
And only modern revenue earning stock would be so classified
306024
23 Jan 2013
East Anglia
WWW X YY ZZ
where
WWW: class number
X: Sub class number
YY: Unit number
0WW X YY 00
where
WW: Class number
X: Sub Class number
YY: Loco number
WWW XX YYY
where
XX: Sub type
YYY: Serial number
Solution to what? Apart from some spotters wanting things nice and tidy what is the problem that needs a solution? Add in the cost of such a suggestion and I'd hazard a guess it will remain firmly on the hypothetical pile ;)
As an aside how are spotters coping with the 315 that now has vehicles from two different original units? Presumably unit numbers are not much use and individual coach numbers are more relevant?
