Using Realtime Trains
grumpyxch
22 Apr 2015
I'm new to this forum, so hopefully this post is in the correct location.
I have recently started using Realtime Trains to study the trains passing through my local station (Christchurch in Dorset). I haven't seen any freight trains through here for some years, so I was surprised to see how many freight paths there were according to Realtime Trains. On Realtime Trains, the timetables for these freight paths have banners that state the train doesn't always run, but when it does the banner will be deleted.
Today there were two freights, in opposite directions, passing here within 20 minutes of each other. Neither timetable showed the banner, so I assumed they were running. I was at the station to witness this 'historic' occasion, but neither showed, and I waited for some time after they were due.
I checked Realtime Trains this evening, and neither train timetable had an indication they were late or didn't run.
Am I misunderstanding Realtime Trains?
Any advice gratefully received. Thanks
Lrd
26 Jul 2010
Can you post a link to the two trains you thought were freights so we can look in to it?
louis97
14 May 2008
Derby
Some freight services are advertised as Run as Required, however just because a freight service does not say this - does not mean it is definitely going to run. Freight service paths should be looked at with a pinch of salt until it reports a departure from its origin.
Lrd
26 Jul 2010
Never mind, found them, here and here.
It looks like they were activated but for whatever reason didn't run. The realtime running times go bold when its running, for example.
Tomnick
10 Jun 2005
Both auto-call schedules, presumably? That means that they're automatically "activated" in the system (two hours before booked departure time at their origin?) whether they're actually required or not. Don't ask me how they decide which should be auto-call and which should be manual-call though!
Does RTT know whether a service is auto-call before it's actually called?
Freightmaster
7 Jul 2009
...I was surprised to see how many freight paths there were according to Realtime Trains.
Basically, yes.;)
RTT does exactly what it says on the tin - it enables people
to track the progress of passenger/non passenger trains in
real time once they are on the move.
What it does not and cannot do is accurately predict which
freight services will run before they have set off, as many
trains are just 'ghost' paths which rarely/never run and even
those which do run are often shown as running Monday to Friday
when in reality they only run once or twice a week.
My full time job for the past 20 years has been to study the
patterns of freight services all over the country and publish
regularly updated timetables for popular locations which only
show the regular runners.
My timetables are intended to act as a companion to RTT,
to enable people to see in advance what they are likely
to see at a particular location on a given day of the week,
so they can choose the best day/time of day to go out.
MARK
grumpyxch
22 Apr 2015
Thanks to all (and to Realtime Trains too). I'll just have to use RTT and hope. They were correct the other day when they listed a 'funny' going from Eastleigh to Weymouth and back, then doing it again. It turned out to be 70408 running light on what I can only assume was a test run.
Regards
Freightmaster
7 Jul 2009
You don't have to hope - just wait for the train you are interested in
to be shown as having departed from its origin: bold times in the
[Realtime] column together with entries in the [Dly] column,
like this Freightliner service from Felixstowe from earlier today:
D6975
26 Nov 2009
Bristol
As a caveat - be warned, if you're sitting near the origin point of a freight it can sometimes go past you before RTT registers it as having left its origin.
Happened to me a few weeks ago at Doncaster.
Phil H
30 Jun 2011
Why are all those locations listed, but sometimes there is a time reported and sometimes a no report?
I can understand it if a train booked for say Northampton, but passes up the fast lane through Weedon, but the ones were it is simply a point between two others yet shows no report?
Another feature of RTT is that it only tracks timings on the booked path.
If a train is diverted en route it will "vanish" at the diversion point.
Say a train booked via the Trent Valley is diverted via Birmingham, RTT will lose it at Rugby and it will reappear at Stafford.
The diversion is not tracked.
louis97
14 May 2008
Derby
Not every point is a mandatory timing point, therefore we don't have any data provided in the data file by Network Rail - even some mandatory points don't have this as well! It is the aim, in the next release, to have every point possible at reporting to report, give me some examples and I can ensure they will report, always a few I miss!
It works the other way as well. TRUST will show Off Booked Route reports at points on the line which it picks up times for but we have no need to show in the plan as they aren't of any relevance to us. Trains south of Bristol do this at places like Nailsea etc, if I recall.
Crossover
4 Jun 2009
Yes, 7 days to search but you can fiddle the URLs to look at specific train running for much longer than that :)
