Validity of 1 month return ticket
Terry Tait
31 Jul 2019
If the return portion of a ticket is valid for a month after the outward journey would it be acceptable to use it more than once, for example, one had a lift in a car to the destination and used the return ticket to come back.
studio_two
28 Nov 2011
You can use the outbound ticket once (on the date stated), and the return portion once.
When you use the return portion, the conductor will normally scribble the date on the ticket (to prevent you from continually reusing it). Of course, if the return ticket is not marked by the conductor, I'm not sure how the TOC can determine if it has been used before - so maybe that is their loss.
maxbarnish
3 Oct 2017
However, many return tickets permit break of journey, so this would not necessarily be a safeguard against multiple use as the start date of the return journey doesn't have to be the end date
Fawkes Cat
8 May 2017
So you use an A-B monthly return to travel by train as follows?
A to B
B to A
(road A to B)
B to A
Simple answer - no.
I was about to refer to the part of the National Conditions of Travel that says this, but curiously there doesn't seem to be a condition that explicitly states this (although it's probably possible to infer it from things like the special conditions for season tickets which explicitly allow unlimited travel between specific stations). But in my view it is true to state that implicitly a ticket is valid for one journey only (or one return journey only) unless (e.g. season tickets) something else is stated.
studio_two
28 Nov 2011
That's an excellent point. I wasn't aware of that. So, it really is down to trust in most circumstances?
maniacmartin
Fares Advisor
15 May 2012
Croydon
Absolutely not valid to re-use the ticket. Its a return ticket, not a season ticket.
mikeg
20 Apr 2010
Selby
Ageed. You would be committing an offence under section 5 of the regulation of railways act 1889 as you would be travelling without paying your fare.
However I'm not sure I understand your question in full. You can use it for one journey in each direction and you also can't use the return portion before the outward one as this invalidates the outward portion. You may generally break your journey (make it in multiple part) however may only make the journey once.
Terry Tait
31 Jul 2019
Thanks for the replies, I will buy a single ticket when I return, I have no intention of breaking the law.
Haywain
3 Feb 2013
It's a pretty good safeguard against regularly boarding at the starting point named on the ticket.
maxbarnish
3 Oct 2017
Agree about that - just not necessarily repeating sections in the middle of the ticket - so it will make it more difficult to use it as a season ticket but still possible to use for various short journeys over the same section of line - not permitted, but I am sure it happens.
SussexMan
23 Oct 2010
To be precise, you can use the return portion before the outward one, but by doing so, you invalidate the outward portion,
