'' Violated the signal ''
Sturdjos
27 Jan 2006
Whenever I pass a caution / double caution / caution and clear signal aspect, I get a 'violated the signal' message....... why's this?
Is there a particular speed limit while going through that signal, or something?
It's on the Hammerwich > Wood Green route, btw
Joe
Nitro
20 Nov 2005
I believe double yellow is about 100mph and single 60-70mph but Im not really sure.
66526
9 Nov 2005
Not really a set speed, more to do with your route knowledge. Shouldn't exceed notch 1 on 170, 158, 323, 156. Give you a general idea. If you're doing 100 for example in a 170 its best to put it into notch 1 as soon as you see the double yellow. If doing over 100 in the HST put it into notch 3 and brake accordingly from there. Same in voyager.
Sturdjos
27 Jan 2006
OK, thanks, but why does it say ''violated the signal'', when i pass them?
Jim
11 Jun 2005
Wick
BVE 2 has a set speed of 35MPH when you pass a signal at yellow (or double) meaning you will get this message, 1 of the flaws of BVE 2 IIRc
Dennis
8 Aug 2005
Trowbridge
I thought that the route.signal command set the speed limits for the signals; above the set speeds the 'violated the signal' warning is displayed. Not 100% sure on this mind - if anyone else knows better please enlighten me!
