Virgin Off-Peak Single (Online only)
RYS
11 May 2011
Guess.
Hi all. I'm need to travel from Birmingham International to Euston on Sunday. Ideally I want a flexible ticket. When I use the Virgin website and search for a single ticket BHI-EUS with a Y-P card the only flexible Off-Peak single ticket offered is £28.40.
If instead I search for a return journey EUS-BHI-EUS I am offered "Off Peak Single (Online only)" tickets costing just £14.50 each way.
What's going on here? If they are singles then why aren't they offered when I search for just a single from BHI-EUS.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
This ticket isn't really a single; it used to be called a "saver half", i.e. half a saver return, and can only be bought online along with an advance fare for the other half of the journey. Fares Complification in 2008 renamed it from "saver half" to "off-peak single", which just seems to cause endless confusion.
button_boxer
12 Nov 2009
And if you're booking further ahead you may find that it's cheaper to buy an off-peak-single-formerly-known-as-saver-half plus an advance single in the other direction (and throw away the advance) rather than an off-peak-single-formerly-known-as-saver-single.
You could try using a different TOC's booking engine. Virgin's sometimes seems far too keen to sell two of their off-peak singles, even when a bog standard offpeak return will be less.
No longer here
The Off-Peak Single (Online Only) is half the price of the Off-Peak Return.
SS4
30 Jan 2011
Additionally buying one for both legs results in a Saver Return being printed anyway
Regarding the OP's journey there is always LM if you're not in a rush - £12.55 for a Super Off Peak return
Except the earlier poster found it was £28.40 vs two £14.50s... Only a small difference, but still there.
^^^^ that's not correct, I misread the earlier info.
IMHO Virgin are confusing things here, if you are going to be sold the combined ticket anyway as SS4 points out, why not show it in the fares matrix and let you select it?
Paul Kelly
16 Apr 2010
Reading
I think it's debateable whether showing an off-peak return as two saver halfs is confusing. It is consistent with the rest of the user interface and I'd hazard a guess that it is less confusing to the average non-ticketing expert.
