Virgin trains direct Liverpool to Glasgow trains 27/5/19
Discussion in 'Allocations, Diagrams & Timetables' started by CICERO55, 19 Mar 2019.
  1. CICERO55
    CICERO55 Member
    11
    6 Sep 2018
    Hi does anyone know why virgin trains are operating 3 morning trains from Liverpool to Glasgow on this day and why only this day? Thanks
    Rail Forums
  3. sd0733
    sd0733 Established Member
    1,214
    7 Nov 2012
    There looks to be engineering works north of crewe in the morning with no VT crewe to Weaver before 12ish.
    Makes use of any sets on Edge Hill and gets sets to Scotland to form the back workings when it opens in the afternoon. Looking at it they pick up the path of the Euston-brum-scotland from Wigan
  4. Johnny Lewis
    Johnny Lewis Member
    209
    9 Jan 2011
    York
    There's an Edinburgh to Liverpool and a Carlisle to Liverpool train on Saturday 25th May too, both Pendolinos. Interesting that all trains are routed via Golborne Junction. Are 390s not cleared via St Helens Central? Still: it will be great to see these direct services running, as TPE's long-awaited direct services show no signs of being introduced any time soon....
  5. _toommm_
    _toommm_ Established Member
    1,842
    8 Jul 2017
    Glossop
  6. craigybagel
    craigybagel Established Member
    2,034
    25 Oct 2012
    No idea if they're cleared via St Helens Central, but even if they are, there aren't any traincrew at Virgin likely to sign that route - whereas they do have crews who sign Earlestown. I suspect they may have had to double man them though as I'm not sure there are any crews who sign both Golbourne - Earlestown and Earlestown - Liverpool.
  7. _toommm_
    1,842
    8 Jul 2017
    Glossop
    That may be why the timetable is quite lax through that area so caution won't be thrown to the wind...
  8. craigybagel
    2,034
    25 Oct 2012
    They don't normally timetable services slowly because certain crews don't go over a route that often. It's probably timetabled lax to fit around all the other services that normally run through there. If you sign a route, you're expected to be competent enough to run at line speed.
  9. _toommm_
    1,842
    8 Jul 2017
    Glossop
    It was more the fact that crew won't sign all of it so will have to be piloted, as to why they'll be going slower, as opposed to it just being a little used bit of line.
  10. Ianno87
    Ianno87 Established Member
    3,955
    3 May 2015
    No, AIUI (other experts may be better informed), pilot drivers should be able to route-conduct a driver unfamiliar with a route at normal line speed (although in practice it will probably be a little bit more cautious than usual).
    All the extra time in the schedules is shown as Pathing time (NR Capacity Planning-specified). If it was mandated by Virgin to cover unfamiliarity, it would be shown as Performance Time (TOC-specified)
  11. driver_m
    driver_m Established Member
    1,854
    8 Nov 2011
    Liverpool depot sign as far as Wigan so no double crewing necessary. However Central is not on our route cards. They're for engineering reasons. Line blocked till 1200 at Crewe.
  12. craigybagel
    2,034
    25 Oct 2012
    Thanks, wasn't sure if you signed up that way. Is the idea you sign Wigan so you can work Wigan - Chat Moss - Manchester - Crewe during engineering work? When I worked at Virgin everything went via Chorley when ever there was a block north of Crewe but I understand Virgin never go that way anymore since Chat Moss got electrified?
  13. STANDISH
    STANDISH Member
    193
    10 Jun 2013
    Just to confirm Virgin trains are going via Chorley this Easter holidays. Preston and the next stop is Stockport, service only running to Birmingham International because of engineering works further south. Check details on RTT on Easter Saturday afternoon.
  14. craigybagel
    2,034
    25 Oct 2012
    So they are. Although now they can run 390s over the route which certainly wasn't an option in the past.
  15. driver_m
    1,854
    8 Nov 2011
    More to do with stock moves that went from Edge Hill to Preston direct as to why Wigan is on our cards. Originally Liverpool signed Preston, then just to Winwick In, but it's now Wigan .
  16. dk1
    dk1 Established Member
    6,407
    2 Oct 2009
    East Anglia
    Trains would run at line speed.
  17. driver_m
    1,854
    8 Nov 2011
    That is totally incorrect, you either sign a route or not. But it's irrelevant anyway as no conducting will be needed.
  18. craigybagel
    2,034
    25 Oct 2012
    Learn something new everyday, ta for that.
  19. tsr
    tsr Established Member
    7,165
    15 Nov 2011
    Between the parallel lines
    Come to think of it, I can't think of any occasion where timetabling would account for simply driving slowly over a diversionary route. If anything, any diversionary diagrams I've seen have tended to be on the optimistic side or else entirely normally timed.
    It's worth adding that on many routes there are differential speeds for different traction, and this can mean that if any unusual classes of loco/unit are diverted, they may be obliged to stick to lower speeds than a passenger would observe on normal timetabled services. This could give the incorrect impression that the driver is going slowly because they are unfamiliar and/or being piloted.
Share This Page
