I did a FoI request regarding this https://www.whatdotheyknow.com/request/virgin_trains_free_wifi#incoming-963232
Data use has risen so much apparently that they can't do the free wifi in standard class and is just limited to first class (which it always was).
Apparently this has already happened:
Additional internet capacity on Pendolinos plus failover capability between CCUs on each train
Greater throughput enabling Virgin to process more internet data simultaneously across all trains
Improved onboard capacity and performance. Before the work, the maximum performance, shared across the whole train, was c3Mbps. Pendolinos can now achieve up to c90Mbps.
I find this hard to believe, as when I enquired on virgins twitter it said that it was restricted to first class because they couldn't do the lineside upgrades which would improve the train backhaul speed. But the DfT think this work is already done. Plus, the wifi even in first class is still insanely slow and definitely isn't 90mbit/sec.
As far as I know there is fibre optic cables owned by NR the entire length of the WCML. And obviously there's electricity. It literally requires someone building masts every 1-5km along the route. NR are doing this but it won't be until 2018ish, some 6 years after they started it. Not good enough. 800MHz LTE is likely to make this a lot better before then.
Why not just do what Three does for people roaming with its 'free' Feel at Home service. Filter out many services and heavily throttle the speed (but, cleverly, don't restrict speed tests!).
I`m with 3 and I have noticed that the `feel at home` service is incredibly variable. I was in Norway and for the most part it was excellent however when I was in Ireland a couple of weeks ago it was shocking kept kicking me off the network at points. I am wondering however if there was another problem there or not.
Sam
0.1mpbs in Paris and Google Maps didn't work. Useless.
You'd have thought so! But plenty of examples of this not being the case on other Three networks around the world.I would have thought that it would have been better in Ireland that it did in Norway as they are using 3 IRL signal, its the same company!
Sam
Did you ask for your money back? I had to with Cross Country Trains it was so bad.After travelling with both VTEC and WCML in the last week, I have to say VTEC's WiFi is far superior. I think apart from a couple of deadspots the signal strength and speed was absolutely superb. Best bit about was that it was free seeing as VTEC give out WiFi codes when you book with them directly.
As for WCML, I paid the £5 for the 24 hours access and the speed and connection was absolutely woeful. It kicked me off more times than I was on it. That said, the route itself is notoriously bad for signal at the best of times. My own mobile had no signal at the best of times.
Whatever VTEC have implemented for their WiFi clearly works.
You can of course buy yourselves a handheld GSMR phone if you like and use that!!
Download Virgin Red app, connect your VTWC account to it, and you can get a free code for 24 hours of wifi every day. Never ends.
Does this work for VTEC too?
If only I knew that when booking advances at work recently.West Coast only I'm afraid. The East Coast offer is 20% off advances.
