Virgin West Coast Open Access Application
theshillito
29 Jan 2014
Crewe
What ever happened to Alliance Rail getting some Pendolinos? I know they gave up on getting them, but are there some knocking about somewhere, or would they have been freshly built?
sprinterguy
4 Mar 2010
Macclesfield
They would have been newly built units, the existing Pendolino fleet is fully utilised on franchised West Coast duties. That plan has been superseded by the use of shortened mark 4 rakes released from the East Coast main line with either class 90 or 91 locos, potentially from Spring next year.
theshillito
29 Jan 2014
Crewe
Thank you. That rules out Virgin doing that. I'm assuming they won't want to build some new trains for this little project.
jh64
3 Sep 2015
I'm sure someone's posted here that some Virgin bods were apparently looking intently at CAF's 397s for Transpennine.
RealTrains07
28 Feb 2019
I thought it was said somewhere virgin would be looking to take 91s and mark 4 for the Liverpool service?
Meerkat
14 Jul 2018
It would be a brave politician who allowed a new long distance diesel service entirely under the wires rather than Avanti WC running full electrics.....
Agent_Squash
22 Jul 2016
It won't be 221s, the environmental lobby will shut it down. What would be interesting if VT/Avanti were forced to do 1tp2h using the new paths, but it seems like the ORR would be given advice to end that. VT/Avanti in direct competition would be very good for the consumer, though.
Agent_Squash
22 Jul 2016
Best tell Virgin Trains that as they seem to think it will be!
Slightly ironic for Virgin considering a significant number of their own WCML ads have been about them being a greener way to travel!
I would struggle to guess what they'd use instead though. But there's no way it would get through in today's political climate.
Carlisle
26 Aug 2012
I actually think this should be rejected on environmental grounds, with them forced to procure some EMUs.
Why, when any alternative is likley to involve running them for many more years under the wires of the ECML & GWML anyway.?
On XC, you mean? Rather a stronger case for using DMUs than a wholly electrified route, no?
If 80x can run at 125 without tilt, perhaps 91+Mk4 would be a better bet. Or ideally new EMUs - 10 car Class 397s would be very nice.
I'm more than a little bit opposed to this - there is really no reason why we should be permitting DMUs on wholly electrified routes any more.
Carlisle
26 Aug 2012
On XC, you mean? .
Yes, unless there’s a serious plan for them to go elsewhere.
As it’s now suggested HS2 won’t finally open until 2030, I think it’s a bit premature to be rushing into replacing a sizeable number of currently 125 mph WCML trains with stock limited only to 110 mph
Then they need to order 125mph EMUs of some kind.
We should not be allowing new services with DMUs running wholly on electrified lines.
Hopefully this will result in a load of bad publicity and the whole thing will just go away (or he will get an order in for some 80x or 397s or something).
pt_mad
26 Sep 2011
Couldn't they have bid class 350/2s and refit them in 2+2?
Wasn't it reported that Avanti WC finalised the rolling stock order with Hitachi last week for the 13 + 10?
If this is, in part, so they can run the Liverpool EMU, then what happens to that order if the paths are given to VT for Voyagers to run?
Would they (Avanti) not have quite a few surplus trains ordered if that happened?
Ianno87
3 May 2015
Network Code Part D (Clause 4.6.2) does state that Network Rail are required to consider Environmental factors when making Decisions on Track Access.
I guess more commonly that will relate to noise and vibration issues (e.g. diesel engines idling in loops near houses).
It would be pretty radical for NR or the ORR to attempt to reject the paths on emissions grounds. The VT counter argument is likely to be "well, it's probably better than every passenger travelling by car".
Yes but then they couldn't also bid for 125mph paths which would extend their journey time and potentially make it harder to path them full stop.
Decision criteria is a bit woolly to be fair, what one person thinks could be quite different to another.
hwl
5 Feb 2012
Presumably this is Virgin trying to get their application in before Avanti have theirs in and be first in the queue?
If Avanti don't get the paths it will be very expensive for DfT.
It's not down to the politicians though, the ORR will decide on a competitive basis, assuming Network Rail can find the paths (not guaranteed).
The 221s won't become free until Avanti's new trains arrive (2022), although Virgin probably don't need the full current fleet (20).
It may be that Virgin have bid for these with the Rosco to avoid XC picking them up (XC franchise currently in limbo).
More IC225s could be used - TfW and GC are only taking a few.
If Avanti can run at 125mph non-tilt on the WCML (also not guaranteed|) then so can Virgin.
Avanti's TAA is online as well. The only point worth mentioning from that is possibly that they reckon NR will be raising some speeds to 125 mph...
Clarence Yard
18 Dec 2014
The decision criteria are for NR to offer paths, not to determine Track Access. Determining Track Access is what the ORR do.
The decision criteria are not pass/fail. They are a list of issues that NR should take note of, where relevant, in offering paths to operators. The ORR may already have granted Track Access to an operator by this time, irrespective of the formal timetable bid/offer process.
Glenn1969
22 Jan 2019
Halifax, Yorks
Is it confirmed that this TAA is still in the pipeline given that it was made by VT while they were still running the WC Franchise and before the award to Avanti unless I am mistaken?
pt_mad
26 Sep 2011
I know it's probably not in the ORRs's remit with this, but would it not be for the greater good if the rolling stock shortage at XC were taken into account? As the Voyagers being snapped up elsewhere could have a detrimental effect on a potential lengthening of trains on the franchised XC north to south operation?
I know it's probably not in the ORRs's remit with this, but would it not be for the greater good if the rolling stock shortage at XC were taken into account? I.e. for the greater good? As the Voyagers being snapped up elsewhere could have a detrimental effect on a potential lengthening of trains on the franchised XC north to south operation?
As there's a goodly number of 222s about to become available, I don't think I'd get too hung up on that. I do however think we should get hung up on a proposal to run DMUs wholly under the wires - and not just any DMU, but one of the most diesel-guzzling kinds with nearly 20 year old engines emitting particulates all over the place.
I have no great issue with them doing it (not that I'm likely to use it), but they really need to procure new EMUs for it assuming 91+Mk4 isn't an option.
M28361M
15 May 2014
The ex Virgin Trains Voyagers are the intended stock for the er... Virgin Trains open access hourly Liverpool service, there’s a track access application appeared:
https://orr.gov.uk/__data/assets/pd...s-limited-daft-track-access-contract-form.pdf
There's an unfortunate typo in that document name. A freudian slip by whoever uploaded it, possibly? :smile:
Looking at Companies House, "Virgin Trains Limited" is listed as a dormant company. Unsurprisingly it is a separate company from the franchised VT operation which was "West Coast Trains Limited", although it seems to have many of the same people involved (or at least it did until 8 December).
RealTrains07
28 Feb 2019
Thats one of the reasons why i think ORR will favour virgin.
Isnt the point of open access operators to create competition in the existing market?
Josh1351
10 Dec 2019
Swansea
The WCML is getting quite congested as each year passes by, more and more open access operators could result in major issues if HS2 is not complete in time.
If they don't favour the franchised operator with a franchise commitment they want their heads examining.
There is already competition (gross incompetition? :D) - LNR. And coaches. And the car, as everyone seems to forget.
