MatthewRead
Virgin Trains use to run to Portsmouth Harbour via Guildford and Haslemere how long did this service last for?
I don't think Voyagers were ever cleared for Portsmouth Harbour, only went to Portsmouth & Southsea.
This photo would indicate otherwise.
https://www.flickr.com/photos/dd677...J8u-BnTij2-C9nJxH-EvVU4b-rN66Y7-r8RYgk-KVgwih (not my photo)
Sam
I would not say so, all that this picture proves is that this unit ran into the High Level platforms! I do recall that some services did terminate there!This photo would indicate otherwise.
Sam
Probably off the point, but 5E79 is an XC ECS move from Eastleigh to Guildford via Haslemere, to form 1E79, 06:02 Guildford to Newcastle. So if you fancy getting up early one summer morn, you can have a photo of a Voyager on the Portsmouth Direct - and the return working (5O40) leaves Guildford at 19:13, having arrived from Newcastle as 1O40 at 18:59.
I have actually travelled on both the revenue services but I'm not sure what the logic for them is. However it would be very handy if they could move the revenue service starting point to Havant.
It acts if nothing else as route retention knowledge if the booked route is shut.
Sam
Not sure of the logic of that. It's the only XC service to use the North Downs route between Reading and Guildford and the only XC ECS move on the Portsmouth Direct, so I can't see what diversion opportunities it would offer. Is it doing something clever with revenue share at Guildford?
Think he means the normal XC route via Basingstoke.
Yes sorry should have been a bit clearer there.
Sam
OK - understood. Do services via Reading to Bournemouth get diverted that way? Diversions from Basingstoke via Salisbury are common enough. I guess it might be an option. Would be interesting to know if all Bournemouth XC drivers sign the Portsmouth Direct.
I was once at Portsmouth Harbour to catch 1722 to Cardiff Cen on one occasion and the Board showed 1720 to Preston as cancelled
The current turn around time in soton is about 30 minutes.If the XC services that terminate at Southampton Central atm ever were to be extended to Portsmouth, how much extra time would they need?
Could they not extend any of the Bristol terminators to Portsmouth? There used to be a short lived Sunday morning Manchester to Portsmouth via Bristol in 2001.
