VSE
Anon87
17 Jul 2019
I applied to Freightliner around a year ago and failed the VSE.
From what I gather I may have lost a life on the enhanced testing but not the national, is this correct? Could someone clear up whether I’ve lost a life for all tocs/focs that use enhanced or just those that use the VSE?
It would also be good to know if there are many tocs/focs that use the VSE! Thanks
TheGoldfish
28 May 2019
I failed the VSE for freightliner as well ... at the same time I was in the application process with arriva london ... and the result killed off both applications and I couldn’t reapply for 6 months . My belief is it does count as one life lost but only for tocs /focs that require a VSE not those that don’t ...
it seems that only those tocs /focs requiring advance level passes use VSE but not those who use the standard pass level ?
Anon87
17 Jul 2019
Thanks mate!
That’s another thing I want to find out. Do all the enhanced tocs use the VSE and if not, does that effectively mean even if you fail it with a toc that uses it, you still have 2 lives left for other enhanced tocs.. if you get my drift!
TheGoldfish
28 May 2019
Thanks mate!
I’d have thought that If a toc doesn’t use it then it has no bearing ... it won’t matter if you failed it previously or not as the opc won’t be requiring you take it...?
I think theres another thread on here somewhere in regards to what tocs require what tests And whether or not theyre standard or enhanced ?
Anon87
17 Jul 2019
Is there really.. I’ll try and dig it out!
Thank you - this forum is incredible!
