VT Trainee Driver - EXAMS.
Discussion in 'Railway Jobs & Careers' started by Lucy, 28 Feb 2019.
  1. Lucy
    Lucy Member
    7
    28 Feb 2019
    Hi all,
    Been accepted through to the second stage of testing; VSE and M7SJT with OPC.
    Just wondering if anyone has done this recently. I’ve been having a crack at the VSE practice and they’re going pretty well from what I can tell, even the third task, where you have to do both tasks at the same time HOWEVER I’m concerned I’m not attacking it correctly.
    I’m doing it from left to right, going from the 1st task to the 2nd and so on and so forth, but I’m wondering now whether I’ve interpreted the instructions wrong...
    Anyone who has done this recently please shout up, I’m about to loose my marbles!!!!
    Rail Forums
  3. Westcoast-ting
    Westcoast-ting Member
    158
    26 Nov 2017
    If you using the practice material then it’s completley different to the actual tests.
    If you google vse train driver their is a YouTube video of stage 1 ( similar but not exact)
    Stage 2 is 2 sets of 3 or 4 shapes which you check against each other.
    Stage 3 is both together.
    If you search this forum there is lots of talk about the vse as it’s quite a hard test
  4. Lucy
    Lucy Member
    7
    28 Feb 2019
    Amazing. Thank you so much for this info! I did do some searching on here but I must need to delve more!
    Really appreciate you replying.
  5. Westcoast-ting
    158
    26 Nov 2017
    If you look at the freightliner trainer driver thread on here from page 4 onwards people are discussing the at home set of tests.
  6. slidingdoors
    slidingdoors Member
    114
    15 Apr 2017
    One of the tasks is the primary task (the one on the right where the shapes change rather than the 'train track' IIRC). So make sure you prioritise that. It's possible to get into rhythm and check the shapes on the right and still have a second to check the track (on the left) for errors. But as said it is pretty challenging. Probably harder than most of the OPC tests you go on to do! <- This refers to stage 3. The first two stages is doing each one independently which is obviously a lot easier.
  7. Lucy
    Lucy Member
    7
    28 Feb 2019
    Ohhhh yes, just checked it now. Heads gone even into more of a melt down! The practise tests are NOTHING like the real ones from what I’m reading; all that time looking at those bloody letters and it’s going to be shapes.
    Doomed; to give up or not
  8. Lucy
    Lucy Member
    7
    28 Feb 2019
    I actually am doomed haha!! So you would say on the 3rd task to prioritise the ‘train track’ than the shapes?
  9. Mgv1349
    Mgv1349 Member
    104
    10 Oct 2018
    I’d prioritise the shapes more than the track as they change faster but keep an eye on the track aswell.
  10. slidingdoors
    slidingdoors Member
    114
    15 Apr 2017
    It actually tells you at the start which to prioritise. And I'm 99% sure it was the shapes.
    Take a deep breath and do it in a quiet room with no-one around and it's honestly not too bad. Quite fun in an adrenaline inducing way :)
  11. Westcoast-ting
    158
    26 Nov 2017
    Yes. But it may have changed so just check.
    As said before part 3 is parts 1 and 2 together.
    Part one is very slow and as you will complete it has a pattern.
    Part two will take a lot of concentration and has high demand periods where your checking 4 pairs not 3. They will also time out and give you an out of time error.
    This is just my opinion but the right hand side is their to distract you from the sedate task on the left ! Almost like train driving the sedate task is interrupted by other things happening like fire alarms, signaling errors etc !
    So follow the instructions, do what you can on the right but don’t miss the left. I never made a fault on the left and missed loads more than I wanted on the right and I’ve passed it a 3 times now I think
  12. Lucy
    Lucy Member
    7
    28 Feb 2019
    Well that’s a a lot of amazing and insightful information guys. Thanks very much.
    I was going to do it tonight but after this I’m going to push it and do it next Friday on my day off. Need to be done by March 11th and as of tomorrow I’m on 05:45 starts for 8 days so maybe Friday morning when I’m alone and fuelled with coffee will be the best option
  13. Firestarter
    Firestarter Member
    372
    15 Sep 2009
    Is this for the Apprenticeship train driver position?
  14. Lucy
    Lucy Member
    7
    28 Feb 2019
    Yes that’s correct, well I’m not 100% sure whether it’s an apprenticeship but it’s for trainee drivers...probably way out of my depth but if I don’t have a go I’ll never know :lol:
  15. Westcoast-ting
    158
    26 Nov 2017
    I would say apprenticeship as the internals closes this Sunday 3rd
  16. Lucy
    Lucy Member
    7
    28 Feb 2019
    The starting pay (although v. nice, not really something I’m too bothered about as job satisfaction takes over with a role like this) is 37k..seems hefty for an apprenticeship. But it’s a serious job and knowledge is money for sure in a profession like this.
    KEEP YOUR FINGERS CROSSED (I’ll be most likely on here on Friday being a typical girl and crying about how horrible it was haha)
  17. FManc
    FManc Member
    298
    21 Jul 2011
    It’s not an apprenticeship in the typical sense with a reduced salary that you would typically associate with this kind of programme.
    It’s essentially a normal trainee role with the same pay, structure etc... but you also gain a qualification in train driving (Level 3) I think it is.
  18. Paddy67
    Paddy67 Member
    23
    21 Mar 2018
    What company is this apprenticeship with that you are talking about?
  19. Set_DRA
    Set_DRA Member
    163
    8 Jul 2015
    Virgin Trains
  20. GJL9916
    GJL9916 Member
    172
    19 Jul 2018
    Not seen anything posted on their careers site?
  21. FManc
    FManc Member
    298
    21 Jul 2011
    Internal only
  22. GJL9916
    GJL9916 Member
    172
    19 Jul 2018
    Ah ok sorry, thought It was missing out there! Cheers
  23. Set_DRA
    Set_DRA Member
    163
    8 Jul 2015
    There was an external application process aswell. I think that was around a year ago.
  24. 390036
    390036 New Member
    3
    15 Mar 2018
    I think you're right and can be related back to this thread last year (albeit Lucy appears to be talking about the OPC Stage before that summarised below).
    https://www.railforums.co.uk/threads/virgin-trains-west-coast-apprentice-train-driver.160946/page-5
    To recap: Virgin Trains parked a large group of successful Stage 1 recruits in their Talent Pool with the intention of reopening another round of recruitment this year. This has now happened because my friend has been invited by the OPC for Stage 2 assessments (at Crewe, across one day) covering:
    · The WAFV Vigilance Exercise
    · The ATAVT Perception Test
    · The 2-Hand Co-ordination Test
    · The Structured Interview
    · and an interview with a manager from Virgin Trains.
Share This Page
