VTEC 05:40 Edinburgh to Kings Cross - seating layout?
ejstubbs
19 May 2016
I'm making a booking on the above train for next week and I've run in what appears to be a glitch on the VTEC booking web site. (Cue much astonishment - not.)
I asked it to reserve a forward facing seat at a table in the quiet coach. It found me a backward facing seat. I went in to the seat map and it showed two tables (seats B23 to B30) with no reserved seats around them. I selected a forward facing window seat and went back to the journey preferences page where it showed the seat I had selected, facing forwards but with no tick next to "table". Which seemed odd.
If I select the seat across the "table" from the one I selected, it shows as backwards facing, but again no tick against "table".
Does the VTEC web site not understand the layout of the company's trains, or is something else going on here?
No longer here
Sounds like it only has one seating configuration loaded in the database that checks if it’s a table or whatever - the 225 sets.
You’re on a HST so while the seat map is correct it looks like the additional validation isn’t set up for that.
ejstubbs
19 May 2016
Is that service an HST? Real time trains shows it as electric haulage. (I'd almost prefer an HST because it makes it that little less likely that the train would be completely banjaxed if the wires came down [again].)
pgfb1306
15 Sep 2015
Having travelled on the 05:40 from Edinburgh once too often for my liking, it is without fail electric. That's why we have the branded set (even though it doesn't end up on it 99% of the time - it would just be too hard!) On departure from Edinburgh in standard on the days I've travelled, it has a very light load which will allow you to choose another seat before Newcastle. It still doesn't get that busy there either. First on the other hand is generally full!!
ejstubbs
19 May 2016
Thanks, that's good to know.
I note that there are no Advance tickets left for the day in question, though. Good job the firm is paying!
No longer here
B23 to B30 are only tables on a MKIV, not a HST - so I got the stock the wrong way around upthread. Still sure it’s a problem with the database though, the database validating table window etc assuming it’s a HST in the map when it isn’t.
mallard
12 Apr 2009
Surely just take the booking an move to a nicer seat on arrival
Technically against the rules for Advance tickets (but obviously OK for all other ticket types), but I've never seen it enforced.
Advance ticket terms and conditions said:
Where applicable, you must travel in the Class and reserved seat(s) shown on the ticket(s).
Hadders
27 Apr 2011
One advantage of the new VTEC site (the only one to be honest) is that you can change your seat reservation. I've done it and it worked fine. You get an email to confirm the new reservation.
Unless the site's been 'upgraded' and the option removed.
Failed Unit
26 Jan 2009
Central Belt
This train is very occasionally HST formed. Had it happen on a Monday morning after engineering works between Edinburgh and Newcastle. All the HSTs were in Edinburgh following the Carlisle diversions. Other services on Friday changed to HST or terminated at Newcastle instead of heading to Edinburgh in preparation.
You may really get a HST.
