Warrington Central Signal Box
Discussion in 'Infrastructure & Stations' started by AK1982, 2 Dec 2019.
  1. AK1982
    AK1982 Member
    33
    24 Sep 2018
    Quite often when I am sitting at Warrington Central I see the shift changeover at the signal box at the station.
    Was wondering following the recent opening of the Manchester centre which has taken a lot of the signalling work for this area over does the Warrington box still maintain control and if so where for?
    Also are there plans in place to close the box and move to Manchester?
    Rail Forums
  3. headshot119
    headshot119 Established Member
    1,814
    31 Dec 2010
    Cardiff
    Warrington Central still controls the area it has for many years. The Warrington Cental side of Widnes, through to the Manchester side of Padgate.
    No firm date for the line to be moved to Manchester ROC.
  4. Freightmaster
    Freightmaster Established Member
    2,024
    7 Jul 2009
  5. AK1982
    AK1982 Member
    33
    24 Sep 2018
    That’s great thanks for the info.
    Just one further question, after Hunts Cross is the line to Lime street controlled by Manchester ROC?
    so in effect the Liverpool to Manchester route via the CLC line would start off being covered by Manchester ROC and end with it too with different boxes along the way?
  6. takno
    takno Established Member
    1,663
    MROC for a bit, then Edge Hill, and then finally MROC again for Lime Street station
  7. louis97
    louis97 Established Member
    1,395
    14 May 2008
    Derby
    Edge Hill closed last month. MROC after Hunts Cross all the way through to Lime Street.
  8. takno
    1,663
    Ugh, missed that. Brb, off to update some diagrams...
  9. Tomnick
    Tomnick Established Member
    5,230
    10 Jun 2005
    It’s absolute block between Warrington and Glazebrook (with an intermediate block section in each direction), so can’t readily be shifted into the ROC without at least a bit of resignalling work. Eccles and Astley on the Chat Moss route are perhaps more unexpected survivors!
  10. The Planner
    The Planner Established Member
    9,468
    Astley got put on the annoying costs too much to deal with pile.
  11. AK1982
    AK1982 Member
    33
    24 Sep 2018
    thanks that is interesting. Sorry for the daft question but what does absolute block mean?
  12. pdeaves
    pdeaves Established Member
    2,794
    14 Sep 2014
    Gateway to the South West
    The method of signalling. It's 'old fashioned' (but still valid) now. More info here: https://www.signalbox.org/block.shtml
Share This Page
