water level in a boiler
R4_GRN
11 Jul 2012
can anyone tell me if the water level gauge in a boiler contains the same pressure as the boiler? seems dangeous to me or is the square glass around the glass tube a safety device in case of the glass breaking?
Does the glass break often?
t o m
7 Feb 2011
They are under pressure but I'm not sure if it is the same as the steam pressure. They can wear around the fixings causing them to break. The glass casing is there for protection if it did break but it also protects the sight glass from damage.
themiller
4 Dec 2011
Cumbria, UK
Yes, the pressure in the gauge glass is the same as in the boiler. This is proved when "blowing down" the gauge glass to prove it and the water comes out as steam. You're right in your conclusion that the glass around the tube is for safety - both for personal safety if the pressurised tube fails and to protect the tube. If you examine the protective glass, you'll see that it's quite thick.
Zoidberg
27 Aug 2010
West Midlands
Are there not constrictors fitted to ensure against massive discharge through a broken gauge glass?
E&W Lucas
21 Jan 2010
Yes, ball valves fitted on the water side, which should more or less seal it on a glass breaking. Life can be entertaining when one fails to seat!
Zoidberg
27 Aug 2010
West Midlands
Thanks for confirming that - and I can imagine the ensuing entertainment stemming from a failure to seat!
R4_GRN
11 Jul 2012
thanks for all the replies, I must remember never to stand in front of a sight glass
