Mikey C
- Joined
- 11 Feb 2013
- Messages
- 6,853
Thus video from 2 years ago looks around the old station, and shows how much of it has been untouched since Eurostar left
Fair enough, that;s interesting, well I can understand on this account why pre-clearance at origin has been used for the vast majority of the time of Eurostar operation.Not correct. In the early years UK passport controls were normally conducted on board the train with two UK Immigration Officers starting at each end of the train and working towards each other. These Officers were based at Waterloo and travelled out to Paris (or Brussels) as passengers, and then worked back officially on a UK bound train. Each train had a special interview room and a small office for them to use. As a back up arrangement, there were also passport control desks at Waterloo which could be used if for any reason no Immigration Officers were on board a train. So, at one time, the first few arrivals at Waterloo each morning had their passports checked there (because that saved putting Officers in hotels in Paris or Brussels overnight) with later trains cleared on board because the timings allowed staff to get to Paris or Brussels to join them. Breakdowns, weather and French industrial action were also factors that sometimes prevented on board clearance, because UK staff were in the wrong place. So a control at Waterloo could be operated instead, almost at a moment’s notice.
Consequently, a decision was taken to move to pre-clearance with staff having their passports checked by UK staff in Paris and Brussels (who live there permanently for up to 3 years). So you don’t normally see on board clearance any more, though as I understand it the protocols are still in place.
Are there any photos of this customs area?
I see, yeah that looks like it. Thanks.I think its the big car park/Motorail area alongside the northbound platform - a kind of makeshift 'holding pen' type arrangement into which to dump a Eurostar-load of passengers if needs be without being let loose straight onto the streets of London.
It is all in Modern Railways from the late 80s and early 90s.That's fascinating. Have you got any more info this?
Yes it did - it was the emergency terminal for "trapped" trains , and a couple of trains were diverted there in my day in 1996-1997 (dates cannot be recalled now) - helped out by organising an emergency 313 shuttle Clapham - Willesden to clear (confused) passengers. A one off.
What do you mean by 'trapped trains'?
In the refurbishment, was this power facility removed?This is why the Class 373 Eurostar trains were built and equipped for 750V dc third rail operation
Just thinking about XC physically removing the parts for tilt on the 221s they have.
Very quickly as in just leaving them down the next time they entered France?At the very least the contact shoes for the third rail were removed upon the move to St Pancras. This is because it was found that if a train had its shoes down it conflicted and caused problems with lineside equipment of some sorts in france. Hence during the waterloo times, there was a concrete block on the french side of the tunnel. If a shoe was not retracted, the contrete block woudl knock it off.
Upon the move to St Pancras, they were very quickly removed.
160 km/h to be preciseVery quickly as in just leaving them down the next time they entered France?
Sounds an expensive (and cheap at the same time) way to solve the problem.Hence during the waterloo times, there was a concrete block on the french side of the tunnel. If a shoe was not retracted, the contrete block woudl knock it off.
Ian Allan (the man himself), in his autobiography, wrote of working in those old offices during WW 2, which in the end were demolished in the 1950s and replaced with the commercial development along York Road (itself now about to be redeveloped again). They must have been Victorian and tremendously dilapadated. He said that rats used to run round overnight, and gnaw at the spines of all the working timetables, which somehow had a particularly tasty form of glue.To sidetrack slightly does anyone know if the L&SWR had completed its rebuilding of Waterloo (stopped by the First World War) whether it would have still had 21 platforms or got even more? The diagram above shows offices extending past the Victory Arch, so if the rebuild had been completed I wonder if the offices between Platforms 15 & 16 (as were) would have been moved further out to form an exterior wall.
Why was the station allowed to be unused for so long? Was it due to the enormous cost of making it suitable once more for domestic services, that they were hesitant to spend the money? We did have a recession after all.The 'domestication project' also cuts back the buffer stops by around 60m. This creates a large new circulating and waiting area for 'Windsor Lines' services that will mostly be relocated to these ex international platforms. That should help relieve crowding in the main part of the concourse which can quickly become particularly severe during the evening peak, especially if there's any disruption at this, the UKs busiest station. The new concourse area will also gain its own connecting passageways to the London Underground station complex below the main terminal, relieving other access routes. These passages used to emerge in the old 'Orchestra pit' in front of the international platforms at a lower level but were closed off when Eurostar moved to St Pancras.
The extra rolling stock to make full use of it has only just been delivered. I expect throughout the time the full timetable could be run from 19 platforms, with all stock in use, then the treasury would have said no.Why was the station allowed to be unused for so long? Was it due to the enormous cost of making it suitable once more for domestic services, that they were hesitant to spend the money? We did have a recession after all.
To be pedantic, the hoist wasn't moved, it was dismantled and (presumably) scrapped. Waterloo and City stock now has to be lifted in or out of the depot by a road crane via an opening alongside Spur Road.Access to the Waterloo & City line also had to be changed - previously there was a hoist that brought vehicles up to sidings on the Windsor side but this had to be moved to the over side of the station (meaning all vehicles are brought in/taken away by road now as well as rail access was lost).
Are there stations that have been built without rolling stock.The extra rolling stock to make full use of it has only just been delivered. I expect throughout the time the full timetable could be run from 19 platforms, with all stock in use, then the treasury would have said no.
I can’t think of any other examples of 5 spare platforms being brought into use without the services to use them...
Historically, yes. See, for example (though possibly going off on a tangent), under the heading "Which stations have… been used but never had trains?" on page http://www.railwaycodes.org.uk/stations/trivia.shtmAre there stations that have been built without rolling stock.
In my opinion and it's only my opinion here, they should have had additional rolling stock much sooner. That is the government's doing.
Did anyone here ever regularly travel on the 18.39 Waterloo to Poole when it was just 5 coaches? I use to do it semi regularly from Clapham Junction, when I use to commute from Harrow. It was a train that connected off an hourly Harrow train and one that connected with a train to Guildford, at Woking. If there had been an 18.52 to Guildford I wouldn't have been on the 5 coach train but there wasn't and isn't.
So in my opinion rolling stock had been overdue when it came.
The 10-car railway was planned even earlier - the original Class 450 Desiro plans were for 100 4-car 450/0 units for outer suburban services and 32 5-car 450/2 units for inner suburban Windsor Line services. But the the Strategic Rail Authority stepped in and wouldn't approve the plans, so 120 vehicles were diverted to Silverlink/Central Trains and the 30 350/1 units were born. Meanwhile SWT was left with 110 4-car 450 units and was later allowed to acquire an additional 17 units giving a fleet of 127 (28 of which were later modified to the 450/5 High Capacity specification for use on the Windsor Lines).I don't think anyone would disagree about the effect of DfT delays on the time taken to organise the additional stock. As it turned out the stretched 458/5s and the 456s (providing 108 vehicles) were a complete fudge compared to what SWT had actually tendered for in 2009, for delivery in Dec 2011. This was originally a CP4 project, and it was planned for 120 - 180 Desiro vehicles compatible with the existing fleet but in 5 car formation. In the early 2009 enhancements delivery plans, all the suburban and Reading platform extensions that you'll be familiar with, and Waterloo International integration with the main station, were all supposedly about to start. The whole thing eventually ran about 5 or 6 years late, and that's assuming this December sees practical completion of P20-P24.
