Waterloo Layout
Daniel
5 Oct 2005
Posted this on another forum and didn't get a straight answer, so...
I know that this probably sounds stupid, (so sorry), but I am making some activities and I can't remember which services start on which platform.
Is it possible for someone to tell me where trains go from each platform, (not including Waterloo International)?
Thanks alot :)
Memmy.
thefab444
27 Oct 2006
The New Forest
Basic rough approximations here, bet someone in the know can fill this in better:
Platforms 1 - 6 Slow services to Hampton Court etc.
Platforms 8 - 11 Fast services on the WoE Line & SWML.
Platforms 12 - 14 Services to Portsmouth via Guildford.
Platforms 15+ 'Windsor' Line etc.
Due to the recent engineering work on weekends at Surbiton, SWML trains have been using Platforms 14+.
Probably a bit vague for you though. :(
Daniel
5 Oct 2005
Thanks alot mate, that gives me a rough idea. I need more detail for the final thing, but I can defo make a start with that, cheers :)
T
Tom
Guest
Basically:
1-4 - Suburban Main
5 - Reserve platform (8 coaches ONLY)
6-7 - West of England
8-9 - Bournemouth & Weymouth (xx35 from 8 generally)
10-11 - Southampton & Portsmouth via Eastleigh
12-14 - Portsmouth via Guildford
From here on its a bit rough but it is what is booked from my details:
15 - Circular services via Kingston
16 - Circular services via Hounslow
17 - Reading
18 - Windsor & Weybridge
19 - Reserve at times, but generally Windsor & Weybridge
Oracle
19 May 2006
Near Ashurst New Forest Station
During the weekend engineering work P19 & 18 have been used for SWML trains via the Windsor Lines and the Byfleet Curve. The 0105 Waterloo-Southampton Central "should" run via the Windsor Lines to Point Pleasant Junction and Wimbledon although not being a Night Owl I have not seen which departure platform it uses..9? My interest is in the cross-overs to/from the Main and Windsor Lines.
It may be a bit out of date now, but look at the timetable in SimSig Waterloo.
Daniel
5 Oct 2005
Chhers for the idea, but got a bit confusing, seemed to have different services using the same platform.
TheSlash
7 Jun 2005
Marwell Zoo
Memorex, it can be different platforms depending on the time of the day and the actual day, then consider engineering works.
