reytomas1228
- Joined
- 15 Oct 2017
- Messages
- 41
Are any of the new lifts to the Underground level open yet?
The ones on P21 and 22 were cordoned off this morning, as were the escalators.Are any of the new lifts to the Underground level open yet?
Should that have really been “21-22 open tomorrow”, given 1-20 were already in normal use?SWRailway tweets saying platforms 1-22 open tomorrow
It works if you consider "open" as an adjective not a verb, i.e. "Platforms 1-22 [will be] open tomorrow", not "Platforms 1-22 [will] open tomorrow",Should that have really been “21-22 open tomorrow”, given 1-20 were already in normal use?
I mean we know railway PR people like to exaggerate a bit, but that seems excessive...
I wondered about that because RTT still shows them in normal use. Maybe they’ll become closed most weekends at some stage?...There was also some speculation above that 19 & 20 might be closed for work to be carried out.
Are they actually saying anything positive about May 2019 changes yet? Wouldn’t be a surprise if they became Dec 2019, as seems to have been suggested in a few other areas, eg the GWR area.Apparently 23-24 to come into use when the May 2019 timetable comes in.
They are available for use in disruption currently not for regular traffic.Apparently 23-24 to come into use when the May 2019 timetable comes in.
Looking at the earlier pictures that concrete box to the right side of the new concourse (P23/24 side above orchestra pit) seems a very poor design feature. Many recent lift shafts seem to be much more lightweight, often using a lot of glass. Seems a bit of a throwback...
It's hard to get any concrete information on the May 2019 timetable. The full changes originally planned for December 2018 certainly seem unlikely.Are they actually saying anything positive about May 2019 changes yet? Wouldn’t be a surprise if they became Dec 2019, as seems to have been suggested in a few other areas, eg the GWR area.
The planning drawings show it is new build over where the end of the P22/23 tracks were filled in. The original lifts down to the Eurostar check-in were on the other side of the “pit” near the P19 gateline.I believe it's original from the eurostar station...
It will also provide a street level entrance to the whole station and the underground from York Rd, once further development outside the station takes place.What is the function of the orchestra pit level other than retail space?
I assume it’s the route between 20-24 and the underground during off peak times (when the escalators on the platforms aren’t in use) to avoid walking across the bridge and round to the main underground entrance. In which case it merely fixes a problem caused by it being the there in the first place! Is it reopening purely for the sake of prime retail space instead of simply having a flat(ish) concourse covering over the area?
Looking at it today, isn’t the Bakerloo/Northern concourse an entire level lower than the orchestra pit level? There seems to be a relatively small set of stairs heading down towards the underground (roughly under the P19 gateline and to the right of the new stairs down from the main concourse), but it doesn’t look as if it will be able to cope with large numbers. I think it will come out where the hoarding is at the foot of the ‘tube’ escalators.It is a shame the original plan to drop the whole concourse opposite platforms 20-24 to ground level didn't go ahead. This would have included modifying the victory arch as well. Would have given much larger circulating space and a better entrance to the tube.
The escalators direct to the Underground, according to the NR press release, will be in use from "early 2019" so I guess we'll find out soon.Looking at it today, isn’t the Bakerloo/Northern concourse an entire level lower than the orchestra pit level? There seems to be a relatively small set of stairs heading down towards the underground (roughly under the P19 gateline and to the right of the new stairs down from the main concourse), but it doesn’t look as if it will be able to cope with large numbers. I think it will come out where the hoarding is at the foot of the ‘tube’ escalators.
I have a couple of photos I’ll try and get from the phone to the internet later...
Odd. According to the planning drawings there can’t really be escalators ‘directly’ to the underground as they only go from platform to orchestra pit level, then there’s another set to underground level, but they are further along the building. But how they then get to the underground gateline seems a bit round the houses as well...The escalators direct to the Underground, according to the NR press release, will be in use from "early 2019" so I guess we'll find out soon.
P23 and 24 in use from May.
I think they mean the escalators on the platforms which lead to the undercroft under the former international platforms. They are there because I used them during the blockade.Odd. According to the planning drawings there can’t really be escalators ‘directly’ to the underground as they only go from platform to orchestra pit level, then there’s another set to underground level, but they are further along the building. But how they then get to the underground gateline seems a bit round the houses as well...
Yes that’s the ones I meant, but that level they reach down to is still another flight above underground level. I cannot see anything that could really be called ‘direct’ towards the Bakerloo/Northern concourse. During the blockade didn’t the route down the escalators end up connecting to the main station peak hours subway?I think they mean the escalators on the platforms which lead to the undercroft under the former international platforms. They are there because I used them during the blockade.
