Waterloo Station Upgrade
Goldfish62
14 Feb 2010
Maybe I'm imagining it, but I'm sure more hoardings and fencing have appeared in the orchestra pit. It certainly looks more cluttered than it did a few weeks ago when it appeared that it was close to opening.
The extra services that SWR will be running from May will require full use of all the platforms and, ideally, full pedestrian access through this part of the station from then as well. At a guess that's now the deadline being worked towards.
hwl
5 Feb 2012
Possibly laydown space for the lift installation that is due to start soon?
Deepgreen
12 Jun 2013
Betchworth, Surrey
I was at the Waterloo International side on Wednesday and was aghast to see that SWR have seemingly seen fit to start dispensing with the word 'station' in favour of the phrase 'calling point'!! The main indicator screen had trains described with both terms, and it beggars belief that anyone in their right mind would see a need to replace the word 'station' with a more cumbersome and unhelpful phrase! This is, in microcosm, symptomatic what is wrong with the railway today - a lack of common sense and commonality of terms which would present a unified and familiar message to passengers. Each TOC seems to think that it must 're-invent' things which have been in the public consciousness for generations/centuries. Is there no-one at any of them that has the vaguest idea of what constitutes good communications? Pathetic.
HowardGWR
30 Jan 2013
Indeed. Apparently the 1805 calls at stations. Weird!
theironroad
21 Nov 2014
While I really can't get exercised about the change like the other poster, it doesn't seem very helpful and station would be preferable. The only rationale I can think of is that some operators use calling points in their on board announcements so maybe they are trying to harmonize things. Or maybe not....
Deepgreen
12 Jun 2013
Betchworth, Surrey
Indeed, maybe so, but the question is why do any operators use "calling points" rather than "stations"?! "Stations" is concise, accurate and time-honoured/ingrained in the public consciousness. There is absolutely no reason to change it to a longer, less familiar and potentially confusing term ("Call Points", which is similar, means something very different). It "exercises" me because there is a fad of inventing new terms all over the railway (and elsewhere) when existing ones are appropriate and well-known. Most spoken and written messages are becoming ever more elaborate, cumbersome and time/space-consuming, when they need to be the opposite. There is a mini-industry devoted to trying to sound 'modern' and 'innovative' where doing so is simply worse! The fundamental principle of good communications (that concise is best) seems to have been lost.
STEVIEBOY1
31 Jul 2010
On this subject, why do they announce where the train is calling at, "Station Stops??"
theironroad
21 Nov 2014
Iirc this came about in the days before modern rolling stock which needs a staff member to enable the doors to be released before they can be actually opened. On older stock , such as slam door where the door was in total control of the passenger, I believe there may have been some incidents where the train stopped at a signal before the station and passengers opened the door thinking they were at the platform (possibly when dark and acting in auto mode and tired). In the legalistic society we were becoming, the guard announcing the 'next stop' is xxx was taken too literally and people were too stupid to differentiate between the next physical time the train stopped (signal) and the intention of the next station to be stopped at.
Both 'station stop' and 'calling point's should be unecessary terms really.
5 Jan 2014
SWR announcemens are also changing for no obvious reasons. At Feltham trains are now anounced as "the next train to depart from platform X is the..."
Rather than the traditional "next train to arrive at platform X is..."
Goldfish62
14 Feb 2010
That's correct. It was introduced in the early 70s following a number of incidents
Goldfish62
14 Feb 2010
But it is perfectly correct though. I'm not sure one is any more traditional than the other??
Goldfish62
14 Feb 2010
Things seem to have ground to a halt if not gone backwards in the past few weeks. The orchestra pit resembles work in progress more than it has done recently, with barriers and materials reappearing. Some of the newly installed wall panelling has been removed. However, there seems to be very little visible activity, with only a handful of workers on site.
5 Jan 2014
Yes both are technically and grammatically correct, however at non terminal SWR and previously SWT stations I have previously only heard the "next train to arrive at..." version.
Bessie
30 Oct 2017
Will all platforms 20-24 be open in time for new May timetable? As others have noted this project seems to have drifted
Goldfish62
14 Feb 2010
I think P23 and 24 are needed for the extra peak services on the Windsor Lines and I can't see any reason why they can't open.
The orchestra pit is a different matter. It fluctuates between looking about to open and being taken apart again. What strikes me is the general lack of activity. There only seems to be a skeleton workforce on site. I was told by an informed source recently that it should have been fully complete and open by December, which then slipped to the end of February. It has clearly slipped again to I don't know when..
Tio Terry
2 May 2014
Spain
Presumably there are some restrictions on what you can do with 20 to 24 if the orchestra pit area is not finished because it is the escape route if, for any reason, 20 to 24 have to be evacuated?
Goldfish62
14 Feb 2010
They were in full use without access to the orchestra pit during the Waterloo blockade.
There are additional escape stairs towards the country end of the platforms as well, but as Goldfish62 mentioned they have already been in full use.
Tio Terry
2 May 2014
Spain
Stairs are fine for able bodied but some provision would be necessary for PRM. It's OK if they have been in use with suitable emergency facilities but if any of the on-going works have affected those facilities then either other facilities need to be provided or special arrangements made. That would include appropriate signage and updating the emergency arrangements plan.
They are no worse than the other 19 platforms without the direct orchestra pit route, and probably far better...
Tio Terry
2 May 2014
Spain
You probably know better than me. 1 to 19 have level access to the concourse via the ticket gate line, I thought the orchestra pit area was being rafted over to provide the same kind of level access? If it's done then there is no problem, perhaps I've misinterpreted the orchestra pit works still on-going as meaning that route is not usable. The only other route I know of is via the hole in the wall between 19 and 20, doubt that would be suitable as an emergency exit for 20 to 24. But I'm sure Network Rail will have it all in hand, in fairness they are pretty good with that sort of thing.
Oh I see. Yes, the orchestra pit is bridged over rather than rafted over, it’s quite a wide bridge which I take to be the main route out towards the concourse, and that bridge has been open and in use since summer 2017, although it had temporary side walls and a temporary roof initially. But going down the stairs at the platform end to the orchestra pit level itself isn’t really a main route to anywhere except the new toilets, yet. There’s also access from the mid platform area down two flights to the LU Bakerloo/Northern level, which corresponds to the P1-19 access to LU via the peak hours subway.
Lastly, and as you already mentioned, there is still the existing ability to get through from P20 to P19 and use the P18/19 barrier line alongside the LU escalators. That route has had a ramp added as well.
The station plan in image 4 of post #119 shows all the various stairs, ramps and lifts, as well as the bridge, but not the dedicated escape stairs towards the country end as the full platform length is not shown.
AIUI there is no specific requirement for “PRM capable” evacuation from the outer end of platforms, based on brand new builds such as Reading or London Bridge. Stairs is all you get.
Ianno87
3 May 2015
IIRC the country end of London Bridge have a PRM refuge point adjacent to the stairs, beyond the limit of the canopies.
Yes, similarly at Reading. It’s got signs and communication and presumably that’s where planned assistance will be provided to cross the tracks.
