Watford tavelcard
Discussion in 'London Underground' started by adamskiodp, 30 Apr 2015.
Thread Status:
  1. adamskiodp
    adamskiodp Member
    85
    16 Sep 2011
    Hi folks,
    Am thinking of having a mooch about London for a day but can't seem to find the ticket I want.
  2. MikeWh
    MikeWh Established Member Senior Fares Advisor
    4,969
    15 Jun 2010
    Crayford
  3. swt_passenger
    swt_passenger Veteran Member
    15,640
    IIRC you won't find such a ticket because Watford Junction is outside the zones.
  4. causton
    causton Established Member
    4,738
    4 Aug 2010
    Cashier five, please
    I think if you buy a Z1-9 + Watford from a tube station (available from their equivalent to a TVM for £16.80), it is technically not an outboundary Travelcard and remains valid to go to Watford and then return into London.
    A National Rail issued paper travelcard from Watford Jn will also include zones 7-9 but is not technically valid once you return to Watford, however if this is claimed you could just buy a single back to Watford High Street to go back to the zones, if not officially valid this is what we locally give people who have a Z1-9 at least!
  5. Bletchleyite
    Bletchleyite Veteran Member
    22,455
    Up and down the south WCML (mostly)
    That's fine *if you go to Watford Met*. Watford Junction is not in the Zones and so you cannot use a 1-9 Travelcard to go there.
    Will be interesting to see if that changes when Watford Met closes.
    http://www.nationalrail.co.uk/static/documents/content/London_Connections.pdf
  6. adamskiodp
    adamskiodp Member
    85
    16 Sep 2011
    Thanks guys. Will probably use PAYG oyster from Watford High Street!
  7. Bletchleyite
    22,455
  8. Deerfold
    Deerfold Established Member
    9,140
    26 Nov 2009
    I don't think either will let you return to London by train, but you could legitimately get a train out and then a TfL bus back until you're at a station within the zones such as Harrow and Wealdstone or Stanmore.
  9. Nym
    Nym Established Member
    8,033
    2 Mar 2007
    Somewhere, not in London
    Watford High Street is in the zones and has bus stops on the 142 and 258 in both directions.
    Zone 8 though if I'm remembering correctly.
  10. Deerfold
    9,140
    26 Nov 2009
    Indeed - that's another.
Thread Status:
Share This Page
