WCML Disruption at Lockerbie
Spaceship323
24 Jan 2020
Nuneaton Trent Valley
I'm currently at Beattock hoping to photograph some 90's and nothings gone northbound for an hour now. According to RTT pendolino 390049 has been held at Lockerbie since 1723 with 1S72 held at Carlisle Station for the last 45 mins.
hexagon789
2 Sep 2016
Animals on line between Motherwell and Lockerbie
palmersears
20 Sep 2011
I'm on 1S72, currently enjoying a beer on the platform at Carlisle. 1S66 the affected service, according to our TM it's a total failure but needs to be pushed into the loop at Carstairs, which could be a problem given 1S69 is between the 397 and the nearest crossover...
EDIT: 1M92 at Carstairs has become 5M92 and is off to rescue 1S66.
24Grange
7 Jan 2021
Baldock
Surely a sheep wouldn't cause a train to " fail" - a cow would, hit one in Wales once in a pacer - that was an experience!
ChiefPlanner
6 Sep 2011
Herts
Trust me - as a callow youth I once assisted the train crew of a class 120 on the Central Wales line in removing an RIP sheep (which luckily did not manage to seriously damage the unit) and about 30 of the deceased's relatives off the line and into a field. Hot day - and there was much strong language. Try herding sheep without a qualified dog.
In those days - there were 37;s at nearby Pantyffynon and one was scrambled , but not needed. Incident was at Llandybie.
Milton Keynes
Depends exactly which bit of the train it hits. If it's something critical it doesn't take a big impact at 100+mph to sit the train down.
390124 just passed southbound on the partially cancelled 1M19. Presumably it reversed at Abington? (as it was 1S69 northbound)
Would appear to have turned at Lockerbie.
palmersears
20 Sep 2011
Indeed. 1S72 cancelled and turned at Carlisle, so we're all now on 1Z81, a 397 to Carlisle. It's very warm, and very full.
1S66 moved under its own power in the end.
4 Jan 2011
Nelson
In this instance a drain cock was sheared off causing the train to lose its air. 100+mph into a lot of things with a bit of weight and density to them won't do the train much good
I was once on a train (Gerald, the Welsh premier train) which hit a dog near Leominster northbound at 90mph.
The air pipe was damaged and the train brakes leaked on gradually over 10 miles or so.
Despite the 57 being at full power, we just made it at a crawl into Ludlow station where they sent for a fitter - from Gloucester. Took 2 hours to arrive and make a temporary fix.
We then limped to Shrewsbury where the train was terminated (no doubt to go ECS to Crewe for repairs).
A pheasant can fail a train if it hits the right part at the right speed!
hexagon789
2 Sep 2016
Didn't one imbed itself in a (was it?) Super Voyager coupler some years back and damage presumably an air valve causing the brakes to bleed on and lock solid?
Rings a bell that it got a mention in one of the railway news publications at the time.
Bertie the bus
15 Aug 2014
Simple. Just use the train. I was on the Cumbrian Coast when the 37s were operating. Just north of Bootle Flossie and her mates were wandering over the track. The driver just went at walking pace constantly blasting the horn. The sheep got the message and after a few hundred yards of scampering about went back into the field.
Aictos
28 Apr 2009
Such as a windscreen? there was a Class 360 last week that I'm aware of that had a smashed windscreen on the drivers side.
24Grange
7 Jan 2021
Baldock
I think, in one of the magazine was a photo of a rescued Buzzard/Hawk or similar which was " scooped" up and deposited in the coupling pocket. Bird could then not get out due to wind resistance. Rescued by the RSPA, bit shocked but none the worse for wear ( no damage to the train I think)
sammyg901
24 Mar 2009
Indeed. Years ago was on a Chiltern 168 that failed at a particularly awkward location between High Wycombe and Princes Risborough after hitting a pheasant that caused the brakes to lock very sharply. Had to wait for a fitter to get to us and IIRC a 165 came and towed / pushed us up to Princes Risborough where the 121 was faithfully waiting to shuttle me home to Aylesbury !
