WCML Disruption in Scotland (02/02/2021)
D6130
12 Jan 2021
West Yorkshire/Tuscany
1M19, 18 40 Glasgow Central - Euston at a stand between Nethercleugh and Lockerbie, reportedly with 'a bogie on fire'. Following train, 9M62, 18 52 Edinburgh Waverley - Birmingham New Street has been turned back at Beattock and is reported to be heading for Glasgow Central, rather than Edinburgh. Northbound services are being held back at Carlisle or Penrith.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
One very very hot (and rare) axle box fire. A TPE 397 is being sent to rescue the passengers from it, while I reckon it'll be a wheel skate job for the Pendolino.
Peregrine 4903
18 Aug 2019
Its lucky Avanti are running a reduced service at the minute, members of their fleet seem to be having freak accidents regularly recently.
While not statistically ruled out, any series of 'freak' accidents in a short period of time should be cause to pause and see if something is going wrong.
Peregrine 4903
18 Aug 2019
What other issues are manifesting?
A pendolino got stuck at Kilburn a few days back because of OHLE issues and I think it is out of use for the forseeable future. Then a voyager had a big incident at Polmadie depot wrecking one of the carriages, not entirely sure what happened but the pictures look bad.
Combine this with the landslip near Rugby and its not been the greatest time for Avanti recently.
D6130
12 Jan 2021
I've just heard that the Pendolino has failed a wheel rotation test, so it definitely can't be moved until a wheel skate has been fitted.
Mcr Warrior
8 Jan 2009
Did most delayed services eventually make it to intended destinations?
I note that 1S82 (the 1557 ex London Euston) eventually made it into Glasgow Central at around 2307, some 128 mins late, after being held at Carlisle for more than two hours.
Ceat0908
10 Jul 2020
Believe the last 3 to Glasgow were terminated at Preston. 1M20, from Glasgow to Crewe was cancelled and 9M62 from Edinburgh to Birmingham new street was turned back to Glasgow. Which means 2 Preston crews stuck north and get to enjoy a taxi ride down the A74 or a hotel room!
Mcr Warrior
8 Jan 2009
Understand from a brief online news report in the Daily Record that there were 14 passengers needing evacuation from a location near to Lockerbie on the affected 1840 ex Glasgow Central service. No injuries were sustained.
JModulo
17 Nov 2013
67A
Not surprising given how hot it got. Will be seized solid.
philthetube
5 Jan 2016
To be fair this is the only one of the freak accidents reported which could be a maintenance issue.
Paul_10
24 Feb 2011
There was one pendolino which had brake issues between Lancaster and Preston quite recently also which meant the train was stranded and passengers evacuated onto another train.
However its just what you call bad luck more than anything. It's probably more unusual because pendolinos are usually very reliable and very rarely cause disruption through train faults.
Whistler40145
30 Apr 2010
Lancashire
So far, Avanti aren't having a good week
What happened the other day that a Voyager substituted for a Pendolino on a Liverpool Lime Street to London Euston diagram
Scotrail314209
1 Feb 2017
Edinburgh
I think that might’ve been the result of the Pendolino for that service being trapped in Polmadie behind the Voyager
Scotrail314209
1 Feb 2017
Edinburgh
1M19 is still stood just north of Lockerbie, blocking the up WCML.
It looks like Southbound trains are crossing over at Wamphrey to run on the down, before crossing over before the station.
NEW POST:
TransPennine Express aren't running anything between Edinburgh and Carlisle.
Both lines are apparently blocked according to JourneyCheck.
Avanti are running Glasgow - Carlisle shuttles non stop via Kilmarnock to connect with trains south.
Looks like this may be going on for a while? The last train to run south was 1M08, the 07:37 from Glasgow - Euston
800001
24 Oct 2015
NEW POST:
Unit is being rescued this morning, aiming to be clear of the line by midday
55002
16 Aug 2019
Ldn
Assuming the Carlisle thunderbird is being drafted?
Apparently the skate team couldn’t get skate underneath in the early hours so another team arrived at 8 this morning to try and get it under. Taken 3 hour line block then will probably use the 57. Info taken from poster on railcam
D6130
12 Jan 2021
I would imagine that if the axle had been locked for some considerable distance there will be some fairly serious rail damage too, possibly resulting in an ESR prior to re-railing. This happened with the freight train locked wheel incident between Carmarthen and Llanelli a few years ago.
aleggatta
28 Sep 2015
Generally, with hot axle boxes, if the axle is hot the wheel will still rotate, resulting in significantly less chances of damage to the track, this can be helped if the axle is a motor wheelset. In this case normally it will only be noticed through the rubber suspension getting too hot and starting to smoke, and on an express service there is less chance of it being noticed on board and more likely by staff when the train passes through a station. It is only when the train is finally brought to a stand and it is inspected, allowing the hot metal a chance to cool that the axle will seize. I remember one time a train at my old company was brought to a stand in the platform, and by all accounts skate fitment was as interesting as it could be having to slide between the platform and the train, whereas if someone was on the ball at the start of the incident (before the fire brigade turned up!) The train could have been brought forwards to a level crossing, making access by all necessary services a lot easier!
Millisle
7 Jul 2013
Lockerbie, Dumfriesshire
About 600 yards perhaps north of Lockerbie station around 15'' ago. I don't think it's going anywhere in a hurry.
Dr Hoo
10 Nov 2015
Hope Valley
But they are not used - reliance is entirely upon lineside hot axle box detectors.
This seems absolutely bizarre. Shades of the East Langton Meridian derailment in 2010 when the driver had received a hot axle box alarm, broken cardan shaft alarm, fire alarm and passcom activation but still re-applied power and delayed braking during his diagnosis process with the Train Management System screen.
Mcr Warrior
8 Jan 2009
Were any Caledonian Sleeper services originally scheduled for last night? Did they get binned? :?:
LeylandLen
28 Oct 2013
Leyland Lancs
As i understand it, there was single line working aroung the stricken 1M19 so the s/b sleeper,1M16 I Think, wAS able to pass on usual route.
I see 1M19 IS 390138 11 Car Pendo, 'City of London '
2021-02-0217:40SERVICE1M191M19 1840 Glasgow Central High Level to Euston390138
