Weirdest Oddities Still on the UK Network?
They can join at Bromley North but at Grove Park where they have to change to another service it's stairs all the way. On very rare occasions if Bromley South is closed for works then trains will run through from Bromley North to Charing Cross or Cannon St and then PRM can dare to use this service.
As a pure terminus station without a regular through service to Central London it must be unique in Greater London. Windsor and E C and St Albans Abbey are the next nearest.
Modron
5 Feb 2019
A bit harsh to call him an 'oddity', but the 'Station Master' at Pontyclun does a great job and is one heck of a character.
Used to see him up at Maesteg CC a few times too.
delt1c
4 Apr 2008
What about Gospel Oak
A Challenge
24 Sep 2016
Gospel Oak is not a 'pure terminus', as it has the North London Line as well as the line to Barking.
Stuart-h
27 Feb 2013
There are a few stations that aren't accessible by road. Corrour has already been mentioned but there are others, for example Middlewood.
Then there's Smallbrook Junction, which is only accessible by rail.
Berney Arms isn't accessible by road. Its accessed by train or boat!
Ayrshire Roy
8 Feb 2019
Although disconnected now by about 20 yards from a siding at Wabtec Kilmarnock there is still a triple guage level crossing.
The line used to run into part of the old Hunslet Barclay offices.
The line across the main road is dual guage with a small section of triple guage crossing a side road.
There is also a set of buffers not connected to anything now in a hedge next to the road.
Is there dual guage or more track anywhere in the UK now?
61653 HTAFC
18 Dec 2012
Another planet...
These notices on Northern 153s (and the unrefurbished 155s, don't recall if the notices are still in place on the refurbished examples) are a bit of an oddity:
frodshamfella
25 Sep 2010
Frodsham
Stanlow and Thornton is a bit like this, the station is within a refinery and I believe your average pedestrian might well be stopped and questioned if walking to the station. Mind you bearing in mind service levels right now if you were going to give it ago, you need to time it right. !
61653 HTAFC
18 Dec 2012
Another planet...
GWR definitely used these too, I haven’t been on a GWR 153 for a while so I’m unsure if they still do.
Though did their "strips" stay orange, though? Says it all about Northern (both past and present) that they repainted the inside of the doors but didn't bother to update the notices. It also raises the question "well if it's not a handle, what is it then and why is it there?"...
No doubt someone on here will know!
LowLevel
26 Oct 2013
Its a retarder to prevent the door travelling too far and getting stuck or coming off it's runner. 153s in certain circumstances are prone to a pressure build up causing the door to open with a bit more vigour than you'd expect, causing the over-travel issue.
The same applies if the crew have to open them without any air in the system, it stops them being pushed too far.
If you pull them too much they split and come away from the door.
Rick1984
23 Aug 2012
Exeter St. Davids also has a foot crossing at South end with the white indicator lights. No idea if ever used.
London Liverpool St. the taxi rank is sort of on the platforms. Quite suprised it's still there.
Parallel
9 Dec 2013
Yes, they definitely used to say 'orange' when the whole of the door was painted pink. Not sure about now though.
matacaster
19 Jan 2013
There is a (disused) wagon hoist which used to facilitate goods being raised into the vast railway warehouse by Huddersfield station.
As an aside, the goods warehouse is a very large building which was being restored to convert to offices?, but that seemed to have stalled once the vast roof had been fixed and all the windows replaced (literally hundreds). If someone is looking for Brexit warehouse space, it might be worth considering!
shaun
10 Nov 2009
The layout of Greenford Station I always found odd. The fact that you have the GWR service terminating in-between two through London Underground lines. Is there anything else like that on either network?
Peter Mugridge
8 Apr 2010
Epsom
Not terminating, but the Central Line at Stratford is between main line tracks - so is pretty much the Greenford situation in reverse. Funnily enough, that's the same tube line as well...
JBuchananGB
30 Jan 2017
Southport
Barking is also quite weird. Terminating bay platform for underground sandwiched between eastbound District line and eastbound C2C. Two lines eastbound underground previously mentioned are sandwiched between Overground GOBLIN terminating platform and the eastbound C2C.
Westbound District uses a dive under to find itself between the westbound C2C towards London and the eastbound C2C towards Grays.
Dai Corner
20 Jul 2015
Euston DC platforms? They're operated by London Overground and I think main line trains do have access but only use them in exceptional circumstances?
Non Multi
11 Dec 2017
I suppose this is more of a quirk than an oddity, but some GWR lines still have mile-posts fabricated out of old broad-guage rail. Anyone else know of any other instances where broad-guage rail is still serving a functional purpose?
The metal wall beyond the bufferstops on the Windsor bay at Slough uses bridge rail with what appears to be an end wall made of Barlow rails. At Paddington, bridge rail appears to be used with bullhead for the fence around the hydraulic buffers at the end of platform 11 and 12.
Slough's Station Jim - where else is there a Victorian stuffed dog in a glass case fundraising on a railway platform? He had a very lucky escape back in 1994.
Doctor Fegg
9 Nov 2010
The Norfolk swing-bridges have been mentioned up-thread, but there's also one just west of Keadby over the Stainforth & Keadby Canal, and one over the River Ouse at Goole.
Church Stretton has a latitude/longitude stone on the Shrewsbury platform. It's a modern replica but the original is at the Steam museum in Swindon.
The bells at Worcester Foregate Street announcing upcoming trains were mentioned in a recent thread.
STEVIEBOY1
31 Jul 2010
Is that the Dog I remember that used to be at Wimbledon Station very many years ago.? I think they may be one one the the National Railway Museum too? (I think I remember also seeing a live dog of a similar breed with a collection tin on it's back at Waterloo Station, again many years ago.
Lucan
21 Feb 2018
Wales
Machines that stamped your name, or whatever you typed in, on a thin aluminium strip for use as an ID tag. Like Dymotape on metal.
dazzler
6 Apr 2018
York
The one at Keadby is even odder, as it lifts slightly, then slides sideways as it swings!
There's another railway swing bridge over the Ouse at Selby Station. The old swing bridge on the former ECML at Naburn is now part of the York - Selby branch of the Transpennine Trail (and no longer swings!)
(For completeness, there are also road swing bridges over the Ouse at Boothferry, Selby and Cawood.)
