Edit: Slightly off thread, but, why is there an 'Easement' for tickets from Harpenden/Luton/Leagrave/Harlington/Flitwick to Wellingborough or stations north of Leicester routed 'Not London' to be valid via Bedford only then?
I'm assuming you mean easement 000083: "Journeys from Harpenden, Luton Airport Parkway, Luton, Leagrave, Harlington and Flitwick to stations north of Leicester on tickets routed Not London are valid only via Bedford, Kettering and Leicester. This easement applies in both directions."
Also 030031: "Journeys from Wellingborough to Luton and beyond may travel via Bedford (Midland). This easement applies in both directions."
Admittedly these are rather odd when they seem blatantly obvious (especially the second).
What is rather odd about the first is the only mapped route from Bedford RP to ex-MML stations north of Leicester is on map MM which shows, funnily enough, the Midland Mainline.
Now if fares to Watford were set by a different company than those to Bedford (for stations north of Leicester) I could understand it - it would probably be so that if the fare check allowed you to also use Watford as a RP, you couldn't go via SAC, SAA, WFJ and then have a choice of routes to NOT:
- one is via Derby
- one is via Bedford anyway on the Marston Vale line
- one is via Stafford/Coventry/Lichfield
- one is via Birmingham and Leicester
Using one of these on a LUT-NOT ticket would be rather exploiting even though the route is valid hence the 'easement' which is more of a restriction.
However, the fares WFJ-NOT, BDM-NOT, and LUT-NOT are all set by EMT so this doesn't make sense :?
