Crun
Many thanks for these photographs. Plenty of information too.
Not a problemMany thanks for these photographs. Plenty of information too.
The piles in question are for the 'Stamford Underbridge'; the slewed Stamford lines will run over each end on a bridge deck, with the aperture below the deck being used for maintenance access and mergency egress from the jacked tunnel.Looks like pile-driving is under way on the western side of the ECML. I wonder if the tunnelling will start soon? Any other news and photographs welcome.
The project? It's needed to allow freight trains from Felixstowe and East Anglia to access the GN/GE Joint Line without crossing the ECML at a crawl, thereby increasing resilience on the ECML and eventually allowing for additional LDHS passenger services (LNER or open access) to operate over the route.Why is this needed?
Aren't the Leicester lines separated from the ECML anyway?
A few new photos from today added to my album: https://www.flickr.com/photos/aebrookes/sets/72157676481607268
I'm a little unsure what the new concrete foundation pads being built alongside the Lincoln Road bridge are for. I'd appreciate if anyone can confirm. My theory is that perhaps this is for a temporary bridge whilst the new span of Lincoln Road bridge is built to pass above the dive under lines. This might just be for temporary utility diversions I suppose.
The tunnel will be a pre-cast structure, jacked beneath the current formation of the ECML (on a curve; a world first!) in (as it stands) September 2020, during a 9-day Blockade. It remains to be seen whether the routes to Stamford & Spalding will be severed as well...When is it planned to create the tunnel under the ECML? Cut & cover?
How long will the ECML be severed?
With a blockade at the dive under position wouldn’t LNER still be able to use the existing flat Werrington Junction?I don’t know but as there’s a blockade, I would think that LNER would be running buses between Peterborough and Grantham, XC running buses between Peterborough and Leicester/Stamford and EMR running buses between Peterborough and Spalding/Grantham.
I don’t know the exact plan so can only hazard a guess but I think we see something similar to that.
Indeed they would. However, the blockade is nearly a year away, so let's wait before we jump to conclusions as to what the diversion situation will be.With a blockade at the dive under position wouldn’t LNER still be able to use the existing flat Werrington Junction?
Yes, the Stamfords will be slewed prior to that.If they are jacking in from the east then it's possible the Down Slow/Down Stamford (which is one track with two functions) will have been relocated further west beforehand and might still be useable. This might allow northbound services to continue running via Grantham and return south via Sleaford.
Would the logical build sequence be to have the ramp structure down to the dive under level almost complete before they even start on the jacked box?Yes, the Stamfords will be slewed prior to that.
If you were to stand on the footbridge linking the Dukesmead estate with the Stirling Way Ind Est, you'll be able to see the rough path of the new realigned tracks; they'll be running roughly over the old Marholm brook watercourse (which has now been diverted).Are they widening the trackbed then as at this point the Stamford lines were pretty close to edge of the footpath/ dirt track alongside
According to the track plan in an early post, the Down Stamford moves well to the west to make room for two new tracks, retaining walls, walkways etc. The Up Stamford probably stays roughly where it is. The logical sequence would be:Yes, the Stamfords will be slewed prior to that. Are they widening the trackbed then as at this point the Stamford lines were pretty close to edge of the footpath/ dirt track alongside
I may have missed something here, but where are the trains supposed to go once the reach Sleaford? Either they would have to run round if continuing northwards otherwise, they would be just doing a giant loop to face Peterborough again....Peascliff could be circumvented if the trains use the Barkston/Allington Curve, that much is certain.
Sleaford has a north-south avoiding line to the east, which was closed for a while but I think is now open again and used by the freight. A northbound passenger train leaves this via a south-to-west curve to get into the station, then takes another curve that branches off the Grantham line at the west end of the station to turn right through nearly 180 degrees then left to re-join the avoiding line towards Lincoln. So north-south trains can also run through the station without reversing.I may have missed something here, but where are the trains supposed to go once the reach Sleaford? Either they would have to run round if continuing northwards otherwise, they would be just doing a giant loop to face Peterborough again.
Thanks for the update.The Down (north/south avoiding) Line to which you refer has recently been re-opened (last couple of years or so) the Up Line remained in situ. When ECML services started being diverted via the GE/GN Joint Line Down HSTs / GC and Hull Trains went via Sleaford station whilst Up Trains did not and on occasion you could see Down trains on the chord between Sleaford West and North Jns waiting for the train ahead to clear section.
Indeed there is. I was working that way last night. However the question that suggested using Allington chord made no acknowledgment that services arriving from the Grantham side would need to run round the train / change ends to continue via the Sleaford North West line towards Lincoln. There is no direct route.Sleaford has a north-south avoiding line to the east, which was closed for a while but I think is now open again and used by the freight. A northbound passenger train leaves this via a south-to-west curve to get into the station, then takes another curve that branches off the Grantham line at the west end of the station to turn right through nearly 180 degrees then left to re-join the avoiding line towards Lincoln. So north-south trains can also run through the station without reversing.
