West Highland Line timetable 2020
adamedwards
4 Apr 2016
I read major changes are planned in particular to Fort William. Does anyone know roughly what is planned yet? Excuse for speculative timetables. Unleash those spreadsheets!
ld0595
1 Aug 2014
With the addition of the 153 bike carriage, changes will absolutely be necessary! I suspect we will see splitting of Oban and Fort William services to facilitate a 4 car 156+153, or perhaps an increase in Fort William services with 2 car 156+153 on the busiest bike/tourist services. Would be nice to see improved connections at Crianlarach between Oban and Fort William, but I accept that passing points may restrict this.
But then again, I don't know much about timetabling!
adamedwards
4 Apr 2016
My hope is for a mid morning train put of Oban. A two car midday train is too late and too full in the summer. Needs a train about 10:00.
hexagon789
2 Sep 2016
I think it was said in the 153 to ScotRail thread that using 153s would mean that present combined Oban/Mallaig trains into/out of Queen Steet would need to be split into seperate workings as 6-cars is the maximum and many are already this length so couldn't have a 153 added on.
adamedwards
4 Apr 2016
I'm aware the other constraint has been using the 156s on commuter trains, hence I assume the 0822 cannot be sooner. I assume that also fixes some evening arrivals.
adamedwards
4 Apr 2016
According to a post in the thread about a possible Faslane station the plan is for hourly trains to Crianlarich alternating between Oban and Fort William. (https://www.railforums.co.uk/threads/new-rail-station-at-faslane-submarine-base-to-be-investigated.190023/#post-4182710) That would be a massive increase to Fort William, less so to Oban, but a much better range of connections at Glasgow to the rest of the UK. Fitting the sleeper in reliably may be fun. That assumes this information is correct.
VT 390
7 Dec 2018
Does the addition of the 153's mean some services will be 5 carriages throughout? as some services to Fort William are 2 156 units already and if so will they be able to keep to current timings?
Also this may be an obvious question but I am slightly confused as to whether the 153's will be just for luggage/bikes or will also be available to sit in?
2812 Adam
23 Nov 2015
Blackpool
If i remember correctly, there will be seating along with the luggage/bikes.
Craig2601
8 Jun 2017
Think it’s a half and half set up with half the coaches for seats. Is there not also a small cafe being set up in the coach too?
bionic
8 Nov 2013
I heard from a member of Scotrail staff that they will be recruiting for more train crew at Mallaig, Oban and Fort William soon, in conjunction with the planned upping of the service.
dk1
2 Oct 2009
East Anglia
I'm premature as always ;) Off to Fort Bill & Oban over the next few days. Not been since 2005 & Spoons have opened in both towns since so require a tick.
Boysteve
25 Apr 2013
Manchester
I don't believe a proper hourly service is possible as the passing loops are in the 'wrong' place. You would need to utilise loops that are about 25 minutes apart to allow a reliable hourly service to operate. Trains would have to pass at Garelochhead but going North the next options are ~20 minutes away and then ~35 minutes. It might be possible to operate two trains in two hours with intervals of 45m/1h15m.
westralian
20 Feb 2019
Arrochar & Tarbet may be 20 minutes away but couldn't Glen Douglas be used as a passing loop?
Boysteve
25 Apr 2013
Manchester
I forgot about Glen Douglas but judging by RTT it's of limited use. Transit from Craigendoran Jn to Glen Douglas is 27-28 minutes which is on the limit with virtually no real possibility of recovering from minor delays. Add a new station at Faslane and it becomes impossible on the current speed profile. Looking Northwards loops can be found at 9, 22 and then 38 minutes. Passing 22 minutes away would be at Ardlui which has some slack and might work as would give a buffer to balance the very tight section to the South! Certainly Southbound services would have an increased chance of being able to depart from Glen Douglas punctually. However this is all without the proposed Faslane station, if it's built forget Glen Douglas!
dk1
2 Oct 2009
East Anglia
Very busy services to both today. 4-car 156 on the Fort Bill only just coped with standing passengers on the Oban 156. Conductor also managed to accomodate 16 cycles on the former train.
