West Midlands weekend 1st class upgrade?
Discussion in 'Fares Advice & Policy' started by GodAtum, 13 Aug 2019.
  1. GodAtum
    GodAtum On Moderation
    2,335
    11 Dec 2009
    How much would it be from Euston to Bletchey, doesn't say on their website?
    Rail Forums
  3. _toommm_
    _toommm_ Established Member
    2,824
    8 Jul 2017
    Whiston/Leeds
    £15 according to BRFares:
  4. John @ home
    John @ home Established Member Fares Advisor
    5,142
    1 Mar 2008
    £10 single or £15 day return.
  5. gazthomas
    gazthomas Established Member
    2,727
    5 Jun 2011
    St. Albans
    So cheaper than buying a first class ticket over a standard one. Seems quite an extravagance given the relatively short distance!
  6. GodAtum
    2,335
    11 Dec 2009
    Thanks very much!
  7. GodAtum
    2,335
    11 Dec 2009
    I have a ticket from Croydon-Victoria. There is a direct train from Croydon to Bletchely via Clapham Junction. Would my ticket cover me to Clapham?
  8. mmh
    mmh Established Member
    1,881
    13 Aug 2016
    I bet they don't sell many of those!
    I'd recommend not buying it in advance, do it on the train from the guard. That way you can see the 1st class section first, decide it's not worth it and save £15! :)
  9. MikeWh
    MikeWh Established Member Senior Fares Advisor
    5,854
    15 Jun 2010
    Crayford
    Yes it would.
  10. GodAtum
    2,335
    11 Dec 2009
    How about beyond, like up to West Brompton or Watford?
  11. mmh
    1,881
    13 Aug 2016
    Yes, that should be fine (in combination with a ticket(s) to cover Clapham Junction to Bletchley of course)
  12. Merseysider
    Merseysider Established Member Fares Advisor
    4,396
    22 Jan 2014
    It's a waste of money, put simply ;)
  13. Jamesrob637
    Jamesrob637 Member
    925
    12 Aug 2016
    A fiver is pushing it let alone fifteen!
  14. philthetube
    philthetube Established Member
    1,843
    5 Jan 2016
    I don't think there is first class on this service, certainly never used to be although the trains have it.
    It used to be classed as a southern metro service and none of them had first.
    Hope this relates to what you are asking.
  15. GodAtum
    2,335
    11 Dec 2009
    Just looked up on NR, it says 1st class seating.
  16. mmh
    1,881
    13 Aug 2016
    First class on Southern is even less worth paying for than on London Northwestern. On the Croydon - Milton Keynes route it will be a a handful of seats at the front and rear of each unit. The rest of the seats in the same carriage will be identical, only without an antimacassar.
    The first section is actually worse, it will be two tables for four with either a very cramped pair of airline seats behind, or tables for four with an uncomfortable and very cramped inward facing single seat behind. The rest of the carriage is far nicer - all table seating lined up perfectly with the windows, for those that like that.
  17. Kite159
    Kite159 Veteran Member
    13,623
    27 Jan 2014
    West of Andover
    Although the 1st class seating on the 377/2s isn't worth paying more for, all you get is a lovely antimacassar. I'm pretty sure there isn't even any dividing doors (as those only started appearing from the 4s)
  18. Bletchleyite
    Bletchleyite Veteran Member
    45,455
    Up and down the south WCML (mostly)
    The only trains operated by WMT on which this could even come close to being worth it are the Class 319s.
    On everything else (2+2 seated at least) I would pay not to sit in First Class.
  19. RSTrains
    RSTrains New Member
    2
    17 Jul 2019
    It really is not worth upgrading to first class at all on LNR. At best you will get a first class headrest that isn't of quality at all and if your lucky your seat may recline (very little and maybe a working plug socket. Don't upgrade is my advice.
Share This Page
