A train brakes and skids for a fraction of a second, resulting in metal being rubbed away from the wheel and creating literally a flat spotSelf-explanatory. I've heard about them but have no clue what they actually are.
For the OP: You can quite often hear it - a thump thump thump sound from the wheels.A train brakes and skids for a fraction of a second, resulting in metal being rubbed away from the wheel and creating literally a flat spot
Particularly noticeable nearer the end of a vehicle, or anywhere on a Pacer in autumn...
Edit - And what Hexagon says.
When this happens the wheels, being softer than the rails will tend to wear away at the contact point with the rail causing flat-spots and additionally the contact point will heat up through friction, causing the metal to alter in propery and spall-out (I forget the precise details of what this means), which I believe can cause cracks in the wheel surface.
With the 143s around here you can hear the wheelflats when they go past sometimes.Our 156s are pretty bad for it in leaf-season, though never so bad I could 'feel' the flats. Though the sound is rather annoying!
the friction of the skid causes metal fatigue, hardening the metal, then the repeated impacts cause cavities to form as the hardened metal breaks up and falls out.
I've heard some good wheelflats on various Mk1s on preserved railways over past few years.
It must be difficult and expensive for these lines to rectify such problems I assume?
i think the lathes are really expensive. TfW's at Cardiff Canton is over 30 years old, assuming they haven't replaced it yetI've heard some good wheelflats on various Mk1s on preserved railways over past few years.
Among many other sounds I would imagine!
I must say I've never noticed the noise of wheelflats other than at close quarters or on the unit itself; though I can hear trains on my two local lines from my house quite clearly most of the time.
the problem isI remember as a kid standing near the line at Cullompton hearing huge bangs as GW HSTs went past. Clearly no one was that bothered in the late 90s early 00s about getting stuff reprofiled!
The investigation found that one of the wheelsets on the damaged wagon had locked up and slid, causing severe wheel flats, before starting to rotate again. Impacts from the wheel flats subsequently damaged the rails as well as equipment mounted on the bogie, some of which partially detached and was dragged under the train, causing damage to track-mounted equipment. The wheelset had locked up and then started rotating again because an object became caught between one of the wheels and the adjacent brake block holder.
I doubt that wheel steel is any softer than rail steel (but I stand to be corrected).When a train brakes and the level of grip (adhesion) is too low to maintain the rate of deceleration then the wheels will tend to lock-up either ceasing rotating fully or turning at a slower rate than the train is moving, effectively the train starts sliding.
The flat is caused by a single point on the wheel being in contact with a moving length of rail therefore the wheel takes the damage. Conversely, with a rail burn, a moving wheel is in contact with a single point of the rail and it is the rail that takes the damage.
Basically, yes, although it doesn't do rails or wheels any good.So in the old videos one sometimes sees of a steam loco with all the driving wheels whizzing around as it tries to get going it will be the track rather than the driving wheels which take a beating?
Generally, in this case the rail would take the brunt of the damage, as the wheel slips the friction will cause heat, the wheel will have time to cool down, where as the rail will be in constant contact with something causing a build up of heat in that part of the rail only. Think of it as if you were running a rope through your hands, the rope will not get damaged from the heat, but your hands will as they are the stationary part? I realise we are comparing steel and rope/skin but the same principal applies.So in the old videos one sometimes sees of a steam loco with all the driving wheels whizzing around as it tries to get going it will be the track rather than the driving wheels which take a beating?
Great Western have always been reactive in their approach to wheelflats and maintenance in general. The likes of East Coast, MML and Grand Central all fitted new Westinghouse/Knorr-Bremse wheelslide protection systems to their coaches and power cars (power cars got them with the upgraded Brush electronics package, as well as improved Wheelslip control systems). LNER and EMT (and GC when they had HSTs) also operate a policy of doing preventative tyre turning which skims the wheels to remove tread damage before bigger problems develop and a much bigger chunk of wheel needs to be removed on the lathe. As a result passengers get a better ride - it is rare to find a wheelflat on an EMT HST even during the leaf fall season, for example - and the operator can get extended wheelset life. As a result those operators have extended time between power car bogie overhauls out to at least 588,000 miles and in some cases 630,000 miles. Meanwhile GWR - who have never done the power car upgrades and have been haphazard with the trailers - are still at 480,000 miles between power car bogie changes and routinely run vehicles with severe flats.I remember as a kid standing near the line at Cullompton hearing huge bangs as GW HSTs went past. Clearly no one was that bothered in the late 90s early 00s about getting stuff reprofiled!
Take a look at this video, about 5:20 in, for some track damage:So in the old videos one sometimes sees of a steam loco with all the driving wheels whizzing around as it tries to get going it will be the track rather than the driving wheels which take a beating?
Very interesting 43096.Great Western have always been reactive in their approach to wheelflats and maintenance in general. The likes of East Coast, MML and Grand Central all fitted new Westinghouse/Knorr-Bremse wheelslide protection systems to their coaches and power cars (power cars got them with the upgraded Brush electronics package, as well as improved Wheelslip control systems). LNER and EMT (and GC when they had HSTs) also operate a policy of doing preventative tyre turning which skims the wheels to remove tread damage before bigger problems develop and a much bigger chunk of wheel needs to be removed on the lathe. As a result passengers get a better ride - it is rare to find a wheelflat on an EMT HST even during the leaf fall season, for example - and the operator can get extended wheelset life. As a result those operators have extended time between power car bogie overhauls out to at least 588,000 miles and in some cases 630,000 miles. Meanwhile GWR - who have never done the power car upgrades and have been haphazard with the trailers - are still at 480,000 miles between power car bogie changes and routinely run vehicles with severe flats.
I remember reading in a railway magazine, a traveller writing that he 'did his duty and reported the flat to the guard'. Is this what one should do?
