I'm reviving this thread for two reasons, one of which admittedly is so that people can see my plan for the Sub-Surface Lines (which no-one replied to :cry
, but primarily, for the following.
It was suggested a year or two ago in the Network Rail RUS for Kent that the Bakerloo line should assume responsibility for the Hayes line currently operated by Southeastern. Now, at present, the Bakerloo line is the quietest of the deep lines (apart from the W&C of course), but this would bring some much-needed investment. On the other hand, there are also plans for the Bakerloo to once again run up to Watford Junction (possibly to coincide with the Met reaching there as well, assuming it actually happens), which would create quite a long route for the Underground; almost 35 miles by my reckoning! A bit of infill (OK, about 5½ miles' worth) between Elephant & Castle and Lewisham later, and I would propose the following...
- Watford Junction to Harrow & Wealdstone - every 10 minutes
- Harrow & Wealdstone to Queens Park - every 3½ to 6½ minutes
- Queens Park to Lewisham - every 3 to 3½ minutes
- Lewisham to New Beckenham - every every 3½ to 6½ minutes
- New Beckenham to Beckenham Junction - every 10 minutes
- New Beckenham to Hayes - every 10 minutes
I would co-ordinate the trains like this:
- Watford Junction to Lewisham
- Harrow & Wealdstone to Bromley South
- Queens Park to Hayes
This would give 18 trains an hour through the rather long central section between Queens Park and Lewisham, which could be augmented at peak times to run 24 times an hour (i.e. 2½ minute intervals) if need be, probably by running local trains between Queens Park and Lewisham.
A few little issues to address though.
Firstly, new stations between Elephant & Castle and Lewisham:
- Walworth (junction of Camberwell Road and Albany Road)
- Camberwell Green (Camberwell Green; where else? )
- Peckham Rye (present station)
- Queens Road Peckham (present station)
- New Cross Gate (present station)
- Deptford (present station)
The one that would jump out to me is Deptford. I have chosen it ahead of New Cross Gate, St Johns, Deptford Bridge DLR and a new station on Lewisham Road because, even though it is a diversion, it is no more of an inconvience by route than further up the line at Paddington; and then one that just happens to create greater interchange potential by providing Greenwich, Charlton, Woolwich et al with a one-stop link to the Bakerloo.
Another issue surrounds Beckenham Junction. I don't even know if the little-used chord between it and New Beckenham is able to handle 12 trains an hour, but ignoring that I am looking further east. Assuming that there is room on the existing line, I would then suggest ceasing Southeastern service at Shortlands and introducing the improved Bakerloo to Bromley as well. Then, from Shortlands (now served by the Bakerloo of course), I would try to burrow under Bromley and serve
both stations there, with the line terminating at South.
And finally, there is the issue of the Overground towards Watford Junction; as I understand it however, said service may well be heading towards its cessation anyway, should the Bakerloo re-extension go ahead.
And this, remember, is just for the Bakerloo line; other proposals I would have include splitting the Northern, a new Central line station close to Park Royal, the Chelney (if it ever happens) serving Clapham Junction, and not Wimbledon as hoped for in the SSL post immediately above, and possibly a completely new line running between Croydon and Stratford (whose alignment - and allowing for the East London Line, benefit even! - is somewhat difficult to determine; you have to agree though, a line connecting London's premier non-central business/development areas would be useful).
