What is this near Ince?
Gathursty
31 May 2011
Wigan
I noticed two signs on the embankment between Ince and Hindley and I don't know what they are.
Location: Manchester bound side alongside Hitchen Foods complex.
Description:
1) triangle on a post. All looks to be made out of concrete.
2) T written on a green background facing away from track next to 1 on a metal pole.
Any ideas?
Thanks.
driver9000
13 Jan 2008
Triangle on a post warned of unworked catch points. A later version was a triangle with an S inside it. Often you'll see these signs in place long after the points were removed.
MadMac
13 Jun 2008
Moorpark, CA
A relatively recent cab video of the Edinburgh South Suburban line showed an “AWB” (Apply Wagon Brakes) sign. I think unfitted trains last ran in the 80s.....
Gathursty
31 May 2011
Wigan
Yes. Green background was dayglo. It must have turn in the wind away from the track and it was next to 1 as in 1) the triangular catch point sign.
Highlandspring
14 Oct 2017
There are quite a few AWB signs still hanging on around the newtork.
Llama
29 Apr 2014
That T board is deliberately facing away from the line.
There are often temporary speed restrictions on the stretch through Ince and up towards Hindley in the summers due to the risk of high rail temperatures on the stretches with steel sleepers (more risk of track buckling/'distorted rails').
The other boards (edit, I should say other associated boards to do with the TSR - the warning and commencement boards) are totally removed but that T board has been there for years, obviously it just gets turned if it's required but it's not actually been used for a few years. IIRC it'd been a differential TSR (30 over 60) when it was actually imposed. In the high temperatures on the hottest days in 2018 & 19 there were track workers monitoring the rail temperatures on the embankment where the sun is uninterrupted rather than imposing the TSR so it would seem tactics have changed.
A T board is a termination indicator which denotes the end of an emergency or temporary speed restriction, normal published line speed applies after the T board.
