What is this? (Not datum plates)
Discussion in 'Infrastructure & Stations' started by reb0118, 1 Jun 2015.
Thread Status:
  1. reb0118
    reb0118 Established Member Fares Advisor
    2,644
    28 Jan 2010
    Bo'ness, West Lothian
    What is the yellow item on the left of the track?
    Rail Forums
  3. DarloRich
    DarloRich Veteran Member
    17,154
    Work - Fenny Stratford(MK) Home - Darlington
    A flange greaser? fnar fnar ;)
  4. Starmill
    Starmill Established Member
    10,119
    18 May 2012
    Manchester
    There's a lot of grease on the track there so I think yes it is :p
  5. DownSouth
    DownSouth Established Member
    1,545
    10 Dec 2011
    In Australia the main effect of a flange greaser is to alert train drivers to the local presence of anti-railway NIMBYs.
    I heard of one case where a new flange greaser was installed at a spot where it was actually needed, while the old life expired greaser was removed and shifted to a noise complaint hot spot on a gentle curve and 'installed' to just sit there and look good ;)
  6. mr_moo
    mr_moo Member
    221
    7 Sep 2009
    Swindon
    Yes, it's a mechanical gauge face lubricator, more commonly known as a greaser. It's installed to reduce rail wear or reduce noise, or both.
    There will be a small attachment to the rail with two metal buttons which are depressed by the passing wheel. This will allow a small amount of grease to seep through the system and be squeezed out ahead of the wheel onto the rail on the running face, which is then transferred onto the train wheels as they pass over.
  7. LDECRexile
    LDECRexile Established Member
    1,783
    30 Jan 2014
    Southport, UK
Thread Status:
Share This Page
