What is this please?
ANDYS
21 Feb 2011
Chesterfield, Derbyshire
This box has just appeared north of Chesterfield on the Down Main. Can anyone tell me what it is please?
Andy S
[url]https://www.flickr.com/photos/[email protected]/25903049303/in/dateposted-public*********[/url]
Sorry, don't know how to put a little picture here!
Do you mean the flange greaser or the wheel impact load sensor?
Edit: See below.
ANDYS
21 Feb 2011
Dhassell,
that was quick. I wondered the same as the same kind of cables are on the crossovers which are just under the bridge.
NajaB
Nearly as quick. Not the flange greaser. That has been there for years and I did not even consider that when I posted the picture. So what does a wheel impact load sensor do, or why has it appeared?
Andy
ComUtoR
13 Dec 2013
I thought it was a greaser :/
They are both greasers. The old one further down the track and the new version with the solar panel in the foreground.
PaxVobiscum
4 Feb 2012
Does the phrase 'Friction Management' in small lettering underneath the 'LBFoster' offer any sort of clue? :lol:
Indeed it does - I hadn't zoomed in on the image initially, just saw LB Foster and thought WILD. Didn't take long to realise I was being thick though, which is a change. :)
PaxVobiscum
4 Feb 2012
And the one behind is Noo-noo from the Teletubbies. :lol:
You can examine similar (possibly identical) ones to both of those up close at Manchester Piccadilly platform 14.
dviner
7 Oct 2010
Why would you have a flange greaser on what appears to be a very straight bit of track? Or does it start to get very curvy just out of shot?
There's a junction a bit north of Chesterfield, so maybe it's because of that?
dviner
7 Oct 2010
I still would have thought the start of the curve should be visible in the picture of the greaser, I mean - it might start to be scraped off before it's needed.
ANDYS
21 Feb 2011
dviner
looking north from the footbridge, where I took the shot, the line curves very gently to the left. This shot shows all four lines here.
https://www.flickr.com/photos/[email protected]/26247857516/in/album-72157663482217545/
The greaser is on the far left line (Down Main) just off the bottom left of the photo.
This photo is taken from the next bridge along looking south (hence the bad sun). The last tanks are about in line with the footbridge. As you can see, there is a junction (Chesterfield North) but I do not think this would affect anything.
https://www.flickr.com/photos/[email protected]/25788167415/in/album-72157663482217545/
Looking north from this same road bridge the line has a gentle 'S' bend before the lines split and the two Barrow Hill lines head off eastwards and the 2 main's go NW towards Sheffield as in this photo:-
https://www.flickr.com/photos/[email protected]/25487459650/in/album-72157663482217545/
Andy S
Trog
30 Oct 2009
It used to be traditional to site the old type lubricators like the one in the background of the photo at 15mm of cant. If that did not work so there was a smear of grease on the side of the rail head through the curve you were trying to protect, you then tried moving the greaser a bit to see if that worked better. The new type spread the grease much further so they are sometimes placed back before the curve at a safer or more convenient point for refilling.
dviner
7 Oct 2010
Fair enough - does get curvy and the grease lasts longer.. Thanks, Andy & Trog.
