What makes Voyagers ‘louder’ than Meridians?
londonmidland
22 Dec 2009
Leicester
As the title says, what is the reason for this?
Initially, I thought it was just because Meridians had better internal soundproofing, however Voyagers seem ‘louder’ externally, too.
Do Voyagers have different and/or bigger and louder exhausts? Upon departure there is that heavy, ground shaking bass. This is noticeable both inside and outside of the train.
Everytime power is applied on a Voyager, you can hear and feel this. On Meridians however, there is a lot less engine noise, with most noise coming from the track ‘running’ and bogie sounds.
There is the usual turbocharger scream, however there is a lot less vibration and deep bass from the engine
I compared both trains by sitting in approximately the same seats, closest to the engine.
I’m intrigued to find out if there are any differences which result in the way things sound.
I don't generally find Voyagers noisy, it's more of a background rumble. I suspect any perceived difference between the two is to do with the seating - Meridians have single-piece, very high-backed "benches" which will block more general noise than the individual seats on the Voyager.
greatvoyager
15 Aug 2019
Exeter
Don’t Meridians have components fitted in different places to Voyagers?
If so would that have an effect?
route101
16 May 2010
Weren't Voyagers derated? I watched one depart Glasgow yesterday and I recall them having more grunt and noise back in the mid 2000s.
43055
8 Mar 2018
According to wikipedia more components are fitted under the floors on a Meridian.
I believe the bodies are different in some way as well.
hexagon789
2 Sep 2016
Yes, but so have Meridians.
More stuff under the floor, because the lack of needing space for tilt equipment enabled them to do so. Also makes for more internal space.
Wyrleybart
29 Mar 2020
South Staffordshire
Also, stuff like CET tanks are down below the solebar so that Meridians are not so stinky. I have seen it written that the exhaust pipes of 220 and 221 pass near to the CET tanks giving them a warm. Not sure if this is true. Theoretically of course, more stuff under the solebar will alter the accoustics of the 222 underframe compared to the ex Virgin designs.
TRAX
2 Dec 2015
France
A tiny part can make a huge difference. If the 222s have a different exhaust muffler, the sound output can be significantly altered.
To me it really sounds like the exhaust is the big difference in sound between a Voyager and a Meridian.
hexagon789
2 Sep 2016
There was supposed to be a bundle of improvements Midland Mainline wanted over the Voyagers and I seem to recall another might have been soundproofing or it might have been something similar
londonmidland
22 Dec 2009
Leicester
I think this could be the possible reason for the differences between the two.
Compare the two passing as full power, you’ll notice the 220/221 is a lot louder and the engine drone is also still audible after passing.
Class 221
Class 222
Rail Blues
2 Aug 2016
I don't think they are significantly louder. I think the noise is massively overplayed by some traditionalists when they were introduced on cross country and west coast routes as they'd replaced loco hauled stock and thus not proper trains. 'The noisy engines thumping away below your feet' is probably accurate for 1st generation DMUs, after 30 odd years of use and abuse, but Voyagers, not really.
greatvoyager
15 Aug 2019
Exeter
That’s interesting, never knew that.
Spartacus
25 Aug 2009
Voyagers have an additional donkey engine to ensure the toilet smell is distributed thoroughly throughout the train ;)
robbeech
11 Nov 2015
I'm currently on 222 022 it's got quite a bad misfire and it's sluggish
It would have to be a rather bad misfire on multiple engines to be "sluggish".
It's unlikely you'd tell if one of the 5 engines was only running on 5 cylinders, 4 would be noticeable.
TRAX
2 Dec 2015
France
It depends. An engine running on 5 cylinders can feel less regular than 4 because of the uneven number of cylinders working (hence why 5-cylinder engines usually vibrate more than 4 or 6-cylinder engines).
londonmidland
22 Dec 2009
Leicester
Quick update - after hearing, seeing and feeling both a Voyager and Meridian depart Sheffield, I can safely say the former is a lot louder. The ground/air even vibrates. As part of an uneducated guess, I put this down to the exhausts.
The exile
31 Mar 2010
Somerset
The thing is, it doesn't have to be "thumping away below your feet" to be intrusive - in fact slow and thumping may be loud but not half as intrusive or headache-inducing as something that is quieter but just the wrong frequency. That "wrong frequency" is probably different for different people, which can't help! The air-con (I think) on one of the later Mk2 variants used to create a whine that I could happily ignore, unless I already had an incipient headache - at which point the journey would become torture unless there was some older stock in the train (thank goodness for those Mk1 buffet cars!)
Bosch91
17 Sep 2019
Newcastle
Both run the same power pack so I would have thought any increase in external noise would be down the the exhaust or intake set up (ie increased turbo whine from a less effective air filter).
gallafent
23 Dec 2010
I only just noticed “Merdians” in the thread title. Given the oft-discussed aroma factors relating to the Voyagers, is this in fact the original (Canadian) French name for these trains? :)
Roast Veg
28 Oct 2016
There's also that audible metallic rattle coming from somewhere in the roof - like a pair of car keys on top of a washing machine on a spin cycle.
gallafent
23 Dec 2010
The worst rattles I remember from them are from the window blinds or other bits of the window surround. Fixable with a bit of used ticket / newspaper stuffed into the crack next to the bit that's rattling.
londonmidland
22 Dec 2009
Leicester
The rattles exist on both Voyagers and Meridians. The former has louder exhausts, which is particularly noticeable when departing over when evening powering up from coasting.
Some are louder than others it seems.
