BurtonM
Could Tower Gateway be reworked at all to allow more arrivals into the City?
One has to consider where people from those new stations will go - if they want to go to Bank in the morning peak, then that's problematic.
This http://www.bbc.co.uk/news/science-environment-34334794 has just appeared on the BBC website. I don't understand it fully but it seems to be advocating slowing down the tube to make it less appealing to switch from road to tube?
So, it's an interesting finding, but has to be taken with a large pinch of salt. The issue is that according to the study, by speeding up one mode of transport, it moves the bottlenecks to the interchange point. If you spread the load out more between both modes of transport, then you have fewer total bottlenecks in theory. However, they haven't actually taken into account the total capacity of the system, just distances and speeds, which means that they're missing a rather crucial modelling component. I'd be more willing to trust flow-based systems.
Would any parts of London benefit at all from the re-introduction of trams?
.... Your other option then becomes segregated rights of way, which it turns out are cheaper if you put them underground. At which point, you have railways instead.
Is the cross river tram absolutely dead and buried?
North of the Thames, is there the room to weeve any new tube tunnels through all the existing stuff (other lines, building foundations, etc, etc) or would any new build now have to be bored underneath everything else?
Would it be worth building Crossrail 2 to be big enough for proper double decker trains or would there be some physical reason (eg having to weave between stuff underground) or would the geology not permit it?
"Too far to be considered an interchange" is the answer. For moderately fit people who know what they're doing it's not too bad - a few minutes walk - but if you're less mobile or unfamiliar with the area it's a big problem.
Buses have their own problems - they're much much slower than trains, carry less people, and are affected by London's godawful traffic.
Thats why trams should replace them in central London......Where the Load Factor is high. This apart from the serious pollution issues.....Buses should be used in the suburbs and trolleybuses should be considered outside zone 2. Politically, it has always been difficult to have trams accepted in London. this opposition mainly from rich people who, never use public transport. Buses never had this opposition, so became widespread.
The BBC seem to have missed the point that on an end to end line (like the Vic for example) one very easy way to improve capacity is to slow the trains down, as you reduce the distance for dynamic overlaps and you can run the trains closer together (subject to signalling constraints of course)...
I know that the Vic line uses ATO, presumably each station is a signalling section in itself, how many signalling sections will be in each length of tunnel between stations?
It's not got signalling sections, it's moving block.
Whichever would provide useful cross line journeys, e.g. East London Line to other lines as part of the London Overground network.
They were a significant problem on London streets which are commonly narrower and tighter than the Continental streets compared to. They were a particular problem where two managed to be running in tandem for blocking all sorts of other traffic. They also had a rate of accidents well above what would be expected, because as they attracted a premium payment for drivers they got the most experience and otherwise accident-minimal drivers at their garage. They also developed a gross liability for passengers boarding through rear doors and not paying fares - maybe London's bus fares which are often several times what you pay for comparable journeys in Continental cities accounted for some of this.It does seem amazing to me that Boris got rid of the efficient people-moving 'Bendybus' that many other major cities use, even where they already have trams.
Metropolitan and District lines to Link with East London Line is one option.
Can anyone else think of which other lines would be useful to have direct connection with each other?
