Whistler40145
Another idea is to extend the LOROL services from Highbury & Islington through to Finsbury Park or further, obviously the freight line would require doubling and brought upto Passenger standards.
I assume the idea of (and issues associated with) an orbital 'overground' service, both clockwise and anticlockwise, have been pontificated here many times before?
I'm not sure if this has been covered or is even relevant, but I was reading the latest rail mag today and it had an interesting bit of the possibility of diverting some Southampton Trains from Clapham Junction, up the West London line to Heathrow then Old Oak Common and terminating at Paddington. So easier interchange with this HS2 nonsense! Might take a bit of pressure off Waterloo and the Northern Line?
You mean like the lines from Highbury & Islington to Clapham Junction via Willesden or Canada Water?
What sort of train frequency do you get on those lines, and do they offer a truly orbital service? If they do, perhaps they should be given a specific brighter colour on the tube map and branded 'London Orbital' or 'TfL Orbital' or whatever?
There is a thread on here somewhere where it was suggested that some Chiltern trains to Birmingham go from Paddington instead of Marylebone, but this suggestion was countered with the fact that Paddington is rather full at the moment, only to increase once Crossrail starts properly, so I can't see any So'ton trains being diverted into Paddington.I'm not sure if this has been covered or is even relevant, but I was reading the latest rail mag today and it had an interesting bit of the possibility of diverting some Southampton Trains from Clapham Junction, up the West London line to Heathrow then Old Oak Common and terminating at Paddington. So easier interchange with this HS2 nonsense! Might take a bit of pressure off Waterloo and the Northern Line?
How easy/hard is it to extend platform tunnels (where there's physically the room to do so)?
This all removes any interaction between Tube and SSL and Tube & Overground. It makes Watford-Bromley a "backdoor" Crossrail.
ELL: Extend to Camden Road and on to the Watford DC. At New Cross, extend to Bromley North.
Extending to Camden Road seems doable, though you would have an issue where the tracks are grouped in a passenger-unfriendly way.
But they wouldn't need to be once the freight was banished, (possibly using some sort of magic spell), as is usually required in many of these NLL improvement proposals.
Oh flying junctions everywhere are very much implicit in the fantasy. Tunnels in the way at Moorgate? Build new, even deeper, platforms.
SpacePhoenix- the district is part of the Sub Surface Lines, as opposed to the Tube. SSL S-stock is much closer (possibly identical?) In floor height to Mainline stock such as 378s. Indeed the whole train is much the same height and supposedly BR Mark 2 or Mark 1 coaches have in the dim and distant past been round the Circle. So beyond signalling systems there's little technical incompatibility. Might even be possible to gradually switch the SSLs over to plain 3rd rail, and/or when the S-stock is replaced get dual voltage stock allowing surface sections to to AC.
And yes, an extra pair of tracks mainly for 100m trains is extravagant south of New Cross. But even I have my limits and extending the ELL platforms to a more ideal 250m goes beyond them. Or does it? Hmm.
If the SSLs could be converted from 4rail to 3 rail would it be easier and/or cheaper to maintain in the long run?
Why is the Victoria line so busy? Was looking at the usage figures for different underground lines and noticed that, going by average journeys per mile, it is by far and away the busiest route and that's including the anomaly that is the one stop only Waterloo and City.
