What railway stations are expected to open in 2018
unlevel42
5 May 2011
The new Rotherham Parkgate Tram-Train station is a siding/branch with no normal NR usage.
The other stations on the route from Cathedral are listed in the Summer timetable (on Realtime).
IslandDweller
5 Dec 2011
The only "new" station on Crossrail is Woolwich which was mentioned in item 14 above. All the other stations on the route are interchange with existing LU or NR stations.
As was pointed out earlier in the thread, that's not so. The Canary Wharf Crossrail station is entirely separate from any existing station. It's actually nearer (but not physically connected in any way) to Poplar DLR and to WestIndiaQuay DLR than it is to either of the existing stations with Canary Wharf in their name. One suspects the "Canary Wharf" name has been chosen for the Crossrail station for 'branding' and 'marketing' purposes - but there is no interchange possibility from the new Crossrail Canary Wharf station to any existing station. Anyone changing lines will need to "beep out" of the Crossrail station, walk a couple of hundred metres, then "beep in" again at a DLR or Jubilee Line station, though I expect these will be set as valid OSI points.
As an aside, the new complex built over the station (which has been completed and open for years now) is called "Crossrail Place" even though the line itself will take the Elizabeth Line name.
InOban
12 Mar 2017
Using this thread's replies so far:
2018
Certain: Maghull North; Rotherham Parkgate
2019
Likely: Warrington West; Robroyston; Worcestershire Parkway
Maybe: Dalcross; Kintore; Winchburgh
Beyond 2020
East Linton; Renton
I think you mean Reston. Renton is on the Balloch branch.
One will reopen I suspect, but not for a few years yet, certainly not this or next year.
PR1Berske
27 Jul 2010
2018
2019
Beyond 2020
East Linton; Renton
Kenilworth will also open this year, not that they're making haste or anything.
PR1Berske
27 Jul 2010
2018
2019
Beyond 2020
East Linton; Renton
Quoting myself but doing so to ask a wider question. Is this "calendar" any more or less accurate now than when ir was first typed? I can't think of any new station announcements beyond the usual aspirations for a while now.
Any further info?
Altnabreac
20 Apr 2013
Salt & Vinegar
Any further info?
I’d move Kintore from Maybe 2019 to Likely 2019 as clearance work is due to start this year and they will be using the line closure next summer to build the platforms before opening in December 2019.
Winchburgh and Dalcross my gut feel is neither will open in 2019 but probably reasonable to leave them as Maybe for now.
