What to do with an old Pacer
GrimsbyPacer
13 Oct 2014
Grimsby
How short is short length-wise?
I don't know what length he meant.
But I'd think they're more suited to Cleethorpes to Barton, Grimsby to Newark, Morecambe to Lancaster, Matlock/Exmouth/Henley/Cromer branch lines than commuter lines around big cities.
I would say around an hour should be the max jouney time on a Pacer.
All shuttle services and lines with overcrowded 153s would be a good line for them.
SpacePhoenix
18 Mar 2014
Is there any suitable articulated diesel unit on the market anywhere that would fit within the UK loading gauge and not fall foul of the emissions regs? If there is hopefully some could be ordered then all the pacers could be turn into baked bean cans
Stadler tend to produce bespoke units in small quantities for the various minor Swiss railways, so might be able to do something based on the GTW or one of their other product lines. However these are probably 30% more expensive than they were last week!
Murph
16 Feb 2010
Finding some sort of diesel engine shouldn't be a problem, despite claims that it's impossible to build a compliant engine, etc. Cummins have a compliant QSK19-R, for example, Vivarail are trying out Ford Transit engines, Perkins have a 6 cylinder 400hp-ish product which might be convertible to horizontal use (if someone was willing to pay, and they could adapt their horizontal tech from the 6.354/2006 ranges), Hitachi have a MTU module, etc.
The major issue is convincing someone that there will be a return on their investment, to get them to commit to the huge amount of cash needed to order a bunch of new DMMU/DHMU/DEMU units. ROSCOs won't do a thing unless a TOC or DfT is prepared to basically guarantee that return.
Personally, I think it's looking more likely that cascaded non-Pacer DxMU units, including HSTs, will be how the Pacer fleets are gradually withdrawn. There's a lot of electrification going around, and that should free up a lot of diesel units. DEMU-ified D78s might well feature in that, if the product turns out well.
I wouldn't rule out a small DMU purchase somewhere, but it may well be a high end high speed express product, displacing older and slower DMUs downwards, rather than a Pacer replacement. That's probably a better long term prospect, I reckon. A cousin to the 700, 800, or new ScotRail EMUs could be the answer if there's enough demand once you shuffle everything else downwards.
SWTH
12 Mar 2013
Shrewsbury/Porthmadog/Exeter
Maximum journey length of 45mins.
As for new DMUs, sooner or later someone will need to order some new suburban stock. I always thought it a missed opportunity that when the 150s were built they didn't order a batch of MSOs (as per the prototype 150/0 units). 3 or even 4-car 150s would be a very useful thing to have now.
Emyr
8 Apr 2014
Finding some sort of diesel engine shouldn't be a problem, despite claims that it's impossible to build a compliant engine, etc. Cummins have a compliant QSK19-R, for example, Vivarail are trying out Ford Transit engines...
If the Ford engine proposed for the D78 can also be packaged for the Pacers, the investment becomes safer as when the Pacers eventually retire the engines can continue providing return on investment as replacements for D78 engines.
This would also ensure the variety of engines in the fleet does not increase.
SWTH
12 Mar 2013
The Transit engine isn't going to be capable of replacing the Cummins L10. You're talking about a 3.2 litre unit that makes 200bhp and 350lb. ft of torque replacing a 10 litre engine that produces 205bhp and 850lb. ft of torque, whilst being under considerably less stress than the 3.2 engine. The torque is the key factor - horsepower is the measure of how much power an engine can produce, but torque is what actually matters.
SWTH
12 Mar 2013
Two of them? :D
You're still 150lb. ft short of what the L10 produces, and you'd need to re-engineer the pacers to have each axle driven. In doing so you increase the drivetrain losses (2x sets of everything to turn), twice the number of engines and gearboxes to maintain, and probably end up with less fuel efficiency at the end of it.
The L10 is a good engine - simple, rugged and reliable. As existing trains do not have to meet the latest emissions regulations, why overcomplicate the issue by throwing money into a re-power scheme for no benefit?
Are the compliant versions the same size as the older versions? I believe part of the problem is (or was) around finding space for the extra exhaust treatment equipment that is needed to make the engine compliant.
Chris125
12 Nov 2009
If manufacturers could easily adapt foreign designs for this country they'd have already done so, alas the combination of loading gauge and platform height does not make this possible irrespective of engine standards.
Manufacturers also need convincing, as was made clear in a recent Transport Select Committee hearing; I imagine justifying the costs and risks of a new DMU design is not easy for what could well be a relatively small, one-off order.
cjmillsnun
13 Feb 2011
That's similar to mine...
GatwickDepress
14 Jan 2013
I genuinely wouldn't mind having them on the Bedford - Bletchley line. When I was up north during a period of temporary insanity a while back, even the dirtiest Pacer was cleaner than the 150 I was on the other day!
Failing that, my partner wants to keep chickens, so they'd make an ideal coop...
richw
10 Jun 2010
Liskeard
FGW 143s are surprisingly pleasant. They've had a good refurb which makes all the difference. Other than the bouncing.
Have Fgw arrange refurbs for all of them and make passengers think they have brand new trains.
interior of fgw class 143 by relex109.com, on Flickr
muddythefish
13 May 2014
What to do with an old Pacer ?
Send it down to Bedford and let them use it on Thameslink.
ed1971
14 Jan 2009
Wigan
The 2020 withdrawal deadline is fast approaching. If no one can come up with a suitable Pacer replacement before then, I wouldn't be surprised if Alexander Dennis were contracted to rebody a lot of the 142s, with bodies similar to the 144s that meet DDA requirements!
Xenophon PCDGS
17 Apr 2011
Are you suggesting using the VAL technology type wheels found on the Paris Metro on Pacers or have I mis-understood?
I feel my attempt at yet another "humourous" jibe at the Pacer fleet and running them as "bendy-buses" on the road appears to have had an unintended side-effect of being the basis for a serious discussion, with a similarity expressed in your posting....:roll::oops:
61653 HTAFC
18 Dec 2012
Another planet...
Neither the 142s nor the 143/144s meet the 2020 accessibility legislation as they are. The difference being that whilst Porterbrook have costed the work that would be required for the 143/144 fleet, Angel have not done so for the 142s. The work that would be required would be broadly similar for both fleets. The condition of the 142s compared to the slightly less terrible pacers is the likely reason for this work being done, or not.
deltic08
26 Aug 2013
Ripon
Rapidash
3 Sep 2013
Torbaydos, Devon
Could always cut them down the middle and convert them into platform shelters, they'd be no noticable difference in the amount of rain that gets in:p
