What would happen if the power failed totally?
Comstock
19 Jun 2012
They must have a plan for this, it may even have happened?
So imagine the tube is totally without power. How do they get everyone out?
Do they keep diesel shutters especially for this? Or battery powered ones?
Or do people simply have to walk to the nearest station?
Vespa
20 Dec 2019
Merseyside
Do any of the trains have batteries for emergency movement to the next station ?
If not I would looking at retro fitting as well as emergency generators.
Domh245
6 Apr 2013
nowhere
No traction batteries and there's no space to retrofit them, nor emergency generators. For the amount of times this is an issue, the great expense and difficulty of installing a backup makes no sense at all
I’m sure London Underground have several battery locomotives that could be used in an emergency
Given the density of the services, limited number of Battery locos, and where they are kept (Acton and Ruislip are the only regular locations IIRC), there's no practical way of rescuing trains with battery locos.
Dstock7080
17 Feb 2010
West London
All battery locos are based at Ruislip now and currently unable to couple to passenger Stock
Domh245
6 Apr 2013
nowhere
Yes, although if all the power went off, you'd also lose signalling, etc so even if there was a means of rescue or limping it to the next station you won't be able to do anything beyond that.
Meerkat
14 Jul 2018
Every train carries a stretcher/carry sheet for this reason
Should have a fold out frame with little wheels - there are rails down there to make things easy!
In this zero power nightmare would there still be communication? The driver can’t start walking people out without knowing that the power won’t come back on at any moment.
py_megapixel
5 Nov 2018
Northern England
Are there not procedures to ensure that the traction current is off in the event of a derailment or a train failure (shorting the live rail to the neutral IIRC)? Presumably the driver would have to apply those procedures so that even if the current came back on, the rails would not be live. Just my speculation though.
Enthusiast
18 Mar 2019
Are the tunnel telephone system wires still active? I know they were not installed on the Heathrow 4 and 5 extensions or the Jubilee extension. I believe pinching them together cut the traction current (though I confess my knowledge of that system is sparse and almost certainly outdated).
Comstock
19 Jun 2012
This is a pretty good argument against driverless trains actually isn't it?
I'd be happy to help carry a stretcher, as I'm sure would many other people, but I'd want a trained staff member in front of me.
philthetube
5 Jan 2016
Unless it is going to take a seriously long time people would not be carried out, all who can walk would and the rest could wait.
Being in the dark on a crowded train is not good, sitting on a train with a few others, also not walkers and a couple of lamps is not a huge issue.
Evacuating a train with a carry sheet would not be done without ambulance and fire brigade present unless there was a dire emergency.
Vespa
20 Dec 2019
Merseyside
I personally think traction batteries should be fitted to new tube trains just for this scenario so the trains can get to the next station and evacuate, this can be used for depot movement too.
I believe class 777 is fitted with traction batteries.
Domh245
6 Apr 2013
nowhere
Given the low floors and general lack of space under the floor, I don't see where you think they can be fitted, the fitment of aircon/cooling units into that space is naturally higher priority, especially given the relative rarity of complete powercuts like described. Depot movements can be done using the 4th rail where present and shed leads where not, exactly as it is now.
Going by this database, the average distance between stations is 1.3km, so on average you're never more than 650m away from a station - in reality often less because the busy underground sections are far more dense in terms of stations and that's got quite a few misleadingly large ones as well such as the fast sections of the Metropolitan and Piccadilly lines. Walking 650m even in the particularly harsh environment of a railway (or tube tunnel) isn't enough of a justification for the expense and complication of batteries IMO
Whistler40145
30 Apr 2010
Lancashire
Presumably all stations that are a distance from the surface are all fitted with emergency lights and the same inside the tunnels?
Dstock7080
17 Feb 2010
West London
Indeed, traction- station lighting- tunnel lighting are from separate supplies, many stations are also changing to back-up battery/stored energy emergency systems.
Meerkat
14 Jul 2018
So if there was an region wide power cut some tunnels and stations would immediately go dark?!
Vespa
20 Dec 2019
Merseyside
You do have some point in this respect, I was considering passenger safety in the first instance, keeping everybody safe inside the train and discharging them at the stations, the other, a worse case scenario if the power comes back on while you're still walking along the tunnel, it would be very serious.
The only other thing I could consider is to keep a back up generator so enough power in the short term even up to shunting speed to get to the stations.
I would rather keep passengers on board than milling about in a high risk environment.
frediculous
23 May 2017
Re: emergency lights. Not only that but 99% of Underground passengers probably carry a smartphone with torch capability
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
During emergency evacuation, it is highly unlikely that the power will come back on. Someone will know that the emergency services, staff and passengers are being egressed along the track...
Domh245
6 Apr 2013
nowhere
Again, fitting things like an emergency generator is nigh-on impossible, so can't and won't happen.
Needless to say that if an evacuation needs to take place, the train is protected first by placing down Short Circuiting Devices . This means that even if the power is restored mid-evacuation the rails won't suddenly go live.
DLR is driverless but has trained staff. But I agree that having each train staffed is a good idea.
In theory it would be possible to have a detrainment take place without any controlling minds knowing. Indeed if my memory is right this more or less happened on the Piccadilly Line on 7/7 - albeit control knew something was massively wrong just not exactly what.
In such a situation the driver would lay SCDs, which should discharge the juice if not already happened, and most importantly prevent accidental recharge by immediately causing the circuit breakers to trip should anyone attempt a recharge.
