Which season ticket should I get?
GodAtum
11 Dec 2009
My travel per day for 5 days a week will be:
Outbound:
  • bus
  • East Croydon - Clapham - Vauxhall
Return:
  • bus
  • Victoria - East Croydon
  • bus (free as Hopper fare)
Assuming there's 251 working days / year. I'm ruling out the Annual Bus & Tram Pass as that's £988.
Option 1:
London Travelcard Zones 1-5 £2920
Option 2:
London Victoria only £1988 + single bus fares (£3.50/day) £878.50 = £2866.50. However I'm not sure if I can exit at Vauxhall NR with this ticket?
Option 3:
London Terminals £2212 + single bus fare (£3.50/day) £878.50 = £3090.50. This ends up being more expensive then the travelcard so ruling this out.
wibble
23 Jun 2010
Do you need to return from Victoria by train? An annual Travelcard for Zones 2-5 would cover East Croydon - Vauxhall, and all your bus journeys for £1,700.
maniacmartin
Fares Advisor
15 May 2012
Croydon
If the Op doesn’t want to have two packed trains every evening with no chance of getting a seat, then yes they need to board at Victoria.
[.n]
8 Apr 2016
Also worth noting the hopper fare will inevitably not work for you a few times at least over the year when there is more than 60 minutes in between the two buses because the Vic-East Croydon trains are delayed
pelli
15 Sep 2016
So the Z2-5 Travelcard saves £1220 (= £4.86 per working day, if there's 251 of them) relative to the Z1-5 one, in exchange for costing £3.50 peak / £1.90 off-peak for every journey from Victoria (or otherwise using the National Rail fare scale in Z1, or £2.80 peak / £1.75 off-peak on the TfL-LU fare scale, or £5.30 peak / £3.00 off-peak on the mixed-mode fare scale). This is using Pay-As-You-Go balance loaded onto the Oyster card for seamless combination with the Travelcard, with the Annual Gold Card discount applying to off-peak journeys (not starting between 6.30-9.30am or 4-7pm on weekdays).
BongoStar
12 May 2024
Twyford
Outbound:
  • bus
Return:
  • bus
Will these always be during peak hours and what level of leisure/non-work travel will you be having?
