ushawk
I quite like how the 455's and 456's look, they look rather unique by having the stuff on the front, think the SWT 455's look better than their SN counterparts though.
A few 455's (455/9's?) also have chopper control, experimentally fitted IIRC?
Nah they remind me of Merseyrail Class 507s like that for some odd reason.
Its the same with the Class 315s, they look great as they are and someone decided to give one 'Electrostar' style headlights!
whats wrong with a class 507?
I do think that the new lights on the 315's are awful, they seem to bee too high up to me.
Although the 456's are pretty bad, there is something worse, the front end of a 458 Juniper...
There were six thus fitted - 5912 and 5916 to 5920; I think they removed the equipment and put the standard 455 stuff in when they were refurbished. From memory the last five were built with it from new but 5912 was fitted after having been used as a Christmas Tree for a long time and was practically rebuilt mechanically / electrically.
What!!!!!!!!
Rubbish man!
Yes i agree it slab fronted, but it looks like nothing else on the network!
I've seen a lot of people hate 456s? I'll be honest I like them, I feel there unique in there own way.
I've no problems with the 507s, its just the lights on the 317/7s look bad (personally) they don't look as bad on the 507s I think it made them look younger, the livery also hepled make them look more modern than they actually are!
Just out of interest and slightly off topic, but what was used before the 455s on the lines where the 455s came into service?
class 508's were mostly used before 455's as 4 car sets and before that it was EPB's, CIG's or VEP's I believe.
I appreciate the Southern have since plated over the 455 corridor connector (would have been nice if this was done the same way as the 318s if they really had to do it) but I don't unserstand why the 456s (or the 321, 320s, 319s etc) didn't get corridor connectors? After all, SWT still use theirs, at least for staff access, and on 317s the connector is open to passengers to allow people to move down the train.
On a sort of tangentally related note, who else regrets that they didn't put the class 210 into series production? They looked quite interesting things; Basically a DEMU version of 317, with a power car at one end, and I think one had half a Valenta and one an MTU engine. I suppose it would have been much quieter than underfloor engines, although I suppose it took up more space.
Interesting point which I recall pondering some years ago when I used the Windsor line every day. I never once saw the SWT 455s have the corridor connector open for passenger use which on refelction was odd, given that most other types that have this facility allow it to be used.
Seems a bit of a waste to specify it if it was not going to be used. Can anyone shed any light on this?
It's not used because IIRC, the way the connection works means that people passing through actually have access to part of the drivers cab. I presume this is the secondmans side; the old slammers used to have the drivers part closed and locked by the partition door that closed off the access to the drivers door vestibule. The secondmans side with the handbrake merely had the front corridor door hooked against it, you could easily get into the secondmans side of the cab. In fact, they became unhooked easily and passengers passing through had to reopen the front connecting door themselves to gain access to the next unit sometimes. I think the 455's have a similar arrangement, cab wise.
Back in the day, this wasn't seen as a problem.
