At an outside air temperature of -54C why would an aircraft have to worry about overheating ? Have you felt your luggage just after it's come out of the cargo hold ? There is no need to be reflecting heat.
In fact modern planes pump their fuel through fuel/engine oil heat exchanger to warm it up. Too much heat is definitely not a problem for subsonic flight. (I believe it was a problem for concorde though)
In flight, I can well believe it wouldn't be a problem. What about when you're stuck on the ground in direct sunlight - especially near the equator ( with insolation > 1kW/m^2 ) ? Then I'd have thought that the albedo of the exposed parts of your airframe could be an issue.
