ddebecker841
I was thinking about this the other day and was hoping the forum could help me out. Why question seems quite simple but even with all my google searches I have no idea why the HS2 can go faster, the suggestions I have come up with include.
It may use a wide gauge track. Which I understand increases stability at high speed.
It uses a different rail profile/ wheel profile combo which is optimised for speed.
It uses better ballast thus reducing the chance of twist etc...
It uses better track materials for both the rail and/or sleepers
I understand they must be using better engines to get that higher top speed, but what stops us implementing this nation wide. Is it a physical limitation or just a monetary one. I also understand that congestion would be a problem specifically if there was fast and and 'slow' trains on the same line. I am specifically talking about phase 1 where they will be going from London to the West Midlands.
